-   -   Crown mitre for Kit cabinet (http://www.diychatroom.com/f14/crown-mitre-kit-cabinet-8928/)
TonyD 06-04-2007 01:28 PM
Could someone help me with angles for a crown cut. The molding is going on top of a kitchen cabinet. The cabinet is a corner unit with font angle of 45 deg for outside corners.
thanks
Tony D
AtlanticWBConst. 06-04-2007 01:40 PM
This link should help get you going:
http://www.extremehowto.com/xh/artic...ticle_id=60354
TonyD 06-04-2007 02:58 PM
AtlanticWBConst., Thanks for the link....I measured and my outside angle is 135 deg horizontal ...Im a little confused because I cannot find a M /BT setting for that particular angle.
Tony D
AtlanticWBConst. 06-04-2007 03:37 PM
Rememer that ''test cutting'' two corresponding inside (or outside) pieces, and then holding them up in place, to check, can also help you figure out the actual angles (if you are having trouble with slightly off degree areas).
joe3534 06-04-2007 08:23 PM
Try this
www.cut-n-crown.com
TonyD 06-07-2007 12:20 PM
I just don't get it.....I don't have any problem with regular 90 deg inside/outside corners. But this 45 deg is crazy..... It's an outside cut so the angle is 135deg. The chart doesn't have theat coresponding angle to show what the mitre and bevel is.
tonyD
Ron6519 06-09-2007 10:41 PM
The total angle is 135 degrees. Each piece will be half that.
Ron
send_it_all 06-10-2007 03:39 AM
put the crown on your miter saw upside down, at an angle so the flat the goes against the ceiling is flat on the bed of the saw, and the flat that goes against the wall is flat on the fence of your saw. Turn your saw to a 22-1/2* outside angle and cut the crown that way...instead of trying to figure out the angles to cut while the crown is lying flat.
