Crown Angle For Slanted Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 10:00 PM   #1
Crown angle for slanted wall
I have a vertical wall that abuts the underside of my stairs. It looks just like the first picture in this thread:
Crown moulding: Flat ceiling to angled wall question
I simply want to have the crown molding terminate into the slant. I can't figure out the correct angle though. I made a mockup of the wall to wall angle with pieces of scrap wood to see if I could set my compound miter saw to it but it didn't work.
I would really appreciate any help you can provide. Thanks in advance.
emaxxman is offline   Reply With Quote
Old 01-07-2012, 10:09 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Most stairs are about 38 degrees. Set your saw on that, and place the crown in the saw, holding it 45 degrees against the fence (the way it sits against the wall/ceiling).
Adjust accordingly.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-07-2012, 10:18 PM   #3
Love for Construction
<*(((><'s Avatar
another option for you is to return the crown molding into the wall before reaching the stair angle. You do this like you would a 90* corner.
-luke-
<*(((>< is offline   Reply With Quote
Old 01-07-2012, 11:10 PM   #4
Adjust accordingly.
The angle is about 42. From your description, it sounds like you're saying to cut it like it was an inside corner (but there won't be an opposing mating piece.) The wall would the be "mating" piece of crown. Is that correct?
Old 01-07-2012, 11:12 PM   #5
I thought about that and even mocked up a scrap piece. It just didn't look right since there were pieces of crown visible from the hallway as well. Thanks for the suggestion though.
Old 01-07-2012, 11:25 PM   #6
Disabled wood vet
titanoman's Avatar
Yes. It will butt into the sheetrock instead of the adjacent crown.
Old 01-08-2012, 06:02 PM   #7
Thanks. I didn't try that cut since it simply didn't look like an inside corner to me. I didn't get a chance to finish the crown this weekend but look forward to finally finishing next weekend.
Old 01-08-2012, 06:28 PM   #8
Disabled wood vet
titanoman's Avatar
An inside corner respecting it's a butt joint, not a 45/45.
Check back next weekend.
Old 01-15-2012, 12:38 PM   #9
Got it done this weekend. At first, I misunderstood your comment about having the crown in the miter saw the way it hung on the wall. After I realized what you meant, it was a snap. Thanks for the help. Much appreciated.
Old 01-15-2012, 01:29 PM   #10
Disabled wood vet
titanoman's Avatar
You're welcome.
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
Tight drilling angle fw2007 Electrical 8 05-31-2008 10:33 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
