Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-15-2005, 09:25 PM   #1
Crooked door
Our front door has really gotten hard to open and close. The door appears to have shifted inside the door frame and now the leading edge scrapes the bottom of the frame when you open and close it. I measured the door frame and it is perfectly square so I don't think it is caused by any foundation shifting. Does anyone have any idea what could cause this and what I can do to fix it?
Clay1g is offline   Reply With Quote
Old 06-15-2005, 10:52 PM   #2
Electrical Contractor
Crooked door
check for loose screws on the hinges. might be that simple
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 06-16-2005, 06:37 AM   #3
Remodeler
MinConst's Avatar
Crooked door
Also check for something rising under the door like a deck or other platform. I one had this problem with a floating deck built tight up to the house. It raised up a good 2-3" and forced the door to become unusable. The deck had to be moved out from under the threshold.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 06-19-2005, 10:24 PM   #4
Contractor
Crooked door
Wood, F-Glass or metal door? How is the perimeter clearance other than where it is binding? Is the gap spacing equal or tapered?
Teetorbilt is offline   Reply With Quote
Old 06-25-2005, 01:55 PM   #5
Crooked door
:confused: i have a new mahogany door i just installed that has a 3/4 gap at top on handle side jam is level /sq. hinges tight , what would cause this..
paulspainting is offline   Reply With Quote
Old 08-31-2005, 12:23 AM   #6
Crooked door
put a level on it . Is it plumb?
Builtrite Residential is offline   Reply With Quote
Old 08-31-2005, 01:08 AM   #7
Crooked door
Sounds like you need to cut 5/8 off the bottom of the handle side jamb. This would be common if the floor was out of level, (down on the hinged side). The floor being 5/8 out of level would be common. If the situation is as I described you could have raised the hinge side 5/8 if you were going to carpet. For like vinyl you would have had to drop the hinge side to the floor, Cut 5/8 off the other side and drop it to the floor. Tile guys have a saw that looks like a trowl which they use to cut jambs after they are installed. You put a piece of 5/8 scrap on the floor next to the jamb and put the saw on top of it and saw away. After sawing, in your case you could problably cut the nails to drop the jamb down. Hope that might help. HS
K2eoj is offline   Reply With Quote
French Doors from Homedepot or Lowes??? johnnytuinals General Discussion 47 01-10-2009 11:00 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Walkout Basement Door allworld Building & Construction 1 06-17-2006 01:50 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
