Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-28-2011, 12:31 PM   #16
Creating a round door jamb
Leah asked for pics so I thought I'd oblige - as well as add my humble solution to this encyclopedia we call DIYchatroom.
I decided to change my RO to a circle (round, whathaveyou) as suggested. I did this by finding my radius:
Then cutting out two circles from a sheet of 1/2" MDF:
After finding the bottom of the circle, I scribed my octagonal RO onto the milled MDF:
Cut and carefully attached new sheething to 1x3 blocks I added to existing octagonal framing. (that wall is 2X3 construction)
Then I ripped, kerfed, and pre shaped/ pre-bent 1/2" AC ply onto the cutouts I had from the MDF RO:
Jamb installed:
I then cut casing out of 1x12. I came up with the keystone idea as I was milling the curved casing. I like the look and it saved my cutting into another 8' 1x12! I distressed the pine casing and will oil it soon:
If I had to do it all over again, I'd definitely make my RO circular from the get-go. I'd also bend maple lams the way scmozle described above. I'm not overly thrilled with the side grain of the AC ply that you can see on the reveal. It's only ~3/16", but it's ugly - and in a few spots, the kerfs are barely visable. The maple lams would have looked much better, but for Joe-DIY, I'm happy with it.
I still have to install a stop, build a door (out of 2x6 vmatch), and hinge it w/ strap hinges. I haven't decided on a handle, yet.
exiledgator is offline   Reply With Quote
Old 02-28-2011, 12:46 PM   #17
Wire Chewer
Red Squirrel's Avatar
Wow looking good!
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 07:00 PM
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 10:00 AM
6" round duct vs. oval independentpete HVAC 1 11-17-2010 05:41 PM
Can I split airflow from a 640cfm hood, 10" round to two 3.25x14 ducts ductdawgz HVAC 10 03-25-2010 04:16 PM
Measuring and cutting ceramic tile around a round tub bdasilva Flooring 2 12-06-2009 10:33 AM
