Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-01-2011, 05:31 PM   #1
Creating a pass through in a wall
Hello everyone, I am cutting a pass through in a wall (bedroom to bedroom). The house was built in the 60's, the walls are made of cheap wood paneling. I have cut most of it away but I'm not sure of the proper way to install added wood (studs?) around the frame of the opening. Any advice is appreciated.
Miss Saigon is offline   Reply With Quote
Old 10-01-2011, 05:56 PM   #2
Moderator
kwikfishron's Avatar
Welcome to the forum.
Is this a load bearing wall you just cut into?
Bet ya didn’t even think about that.
How you proceed depends on if it’s a structural or a partition wall.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 10-01-2011, 07:07 PM   #3
yes, see above
how big is your pass through that has been cut away?
chrisBC is offline   Reply With Quote
Old 10-01-2011, 08:54 PM   #4
Dytecture
Even for a small (2 foot) opening, you'll need to put additional (jack studs) around your opening, not to mention a header 2 x 8 or 2 x 10 if your pass thru is more than 4 feet.
http://www.dytecture.ca
dytecture is offline   Reply With Quote
Old 10-04-2011, 10:58 AM   #5
Is this wire Hot?
Oh-Fudge's Avatar
Search for "framing a window opening" or "framing a doorway" for load bearing wall. Steps are the same except for not putting in the door or window.
Oh-Fudge is offline   Reply With Quote
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Creating a hole in the wall to run wires, a good idea? RyanD General Discussion 6 05-19-2009 04:30 PM
creating a basement window opening in a brick wall amakarevic Building & Construction 5 01-30-2008 12:06 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
