Creating Attic Storage Space - Outdoor Shed - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2013, 09:40 PM   #16
In a little over my head
Rewards Points: 706
Here's a crazy idea. Since you say some of the stuff is heavy. Sister 2x8s to the 2x4s. Notch them so they sit on top of the plate and flush with the top of the 2x4. Then add a jack stud under the 2x8.
ratherbefishing is offline   Reply With Quote
Old 12-19-2013, 10:51 AM   #17
Rewards Points: 87
I've begun the replacement of the attic supports. I just finished ripping out the old 2x4's and and measuring to put up the 2x6's.
Today is a good day
Creating Attic Storage Space - Outdoor Shed-image-2255253418.jpg   Creating Attic Storage Space - Outdoor Shed-image-3716761100.jpg   Creating Attic Storage Space - Outdoor Shed-image-1474224648.jpg   Creating Attic Storage Space - Outdoor Shed-image-2512656946.jpg
ssgtjoenunez is offline   Reply With Quote
Old 12-19-2013, 12:42 PM   #18
Rewards Points: 87
All done except one 2x6 and an attic access ladder. Not bad for a couple hours work.
Creating Attic Storage Space - Outdoor Shed-image-235659217.jpg   Creating Attic Storage Space - Outdoor Shed-image-998407034.jpg   Creating Attic Storage Space - Outdoor Shed-image-2904988673.jpg   Creating Attic Storage Space - Outdoor Shed-image-3221570283.jpg
Old 01-06-2014, 09:36 AM   #19
Rewards Points: 87
So I completed the attic storage space completely yesterday. I mounted a nice attic access ladder and finished the 3/4" plywood throughout. I hung up some temporary shop lights so I can begin work on replacing the subfloor next.
Once the floor is done I'll insulate and be ready for sheetrock.
I'll post some pics in a minute from my phone.
Old 01-06-2014, 09:38 AM   #20
Rewards Points: 87
Here are some pics
Creating Attic Storage Space - Outdoor Shed-image-1306246296.jpg   Creating Attic Storage Space - Outdoor Shed-image-924314738.jpg   Creating Attic Storage Space - Outdoor Shed-image-3910709413.jpg
Old 01-07-2014, 05:11 PM   #21
AHH, SPANS!!!
Rewards Points: 1,166
Hi, Looks great. a suggestion- you need double joists either side of door to attach door at sides for sure and possibly ends?? depending on door install instructions.... easy add on after the fact, screw/ nail them together creating a solid member.
edit.. from pic the joists look like treated lumber, if so use treated approved fasteners Especially where nailing that attic door to treated lumber... not a surprise you or someone wants to find out about in the future
nail/screw joist to rafter really good also with hurricane ties tied to top plates...
Good luck
hand drive is offline   Reply With Quote
Old 01-09-2014, 11:37 AM   #22
Rewards Points: 87
I checked and the ladder doesn't require double joists. This is the second one of these I've installed in the last couple of years and the first was the same installation method.
Old 01-09-2014, 11:49 AM   #23
AHH, SPANS!!!
being a builder anything over 24" span between joists with something hanging from joists ( ladder) require a double joists either side. I would never consider it any other way Especially with people walking up and down said ladder and their lives are in your hands right now and what you do with your hands literally.
Old 01-09-2014, 11:51 AM   #24
Rewards Points: 87
It's not over 24". They are 24" on center which means they are actually 22.5" apart.
The Following User Says Thank You to ssgtjoenunez For This Useful Post:
hand drive (01-09-2014)
Old 01-09-2014, 12:13 PM   #25
AHH, SPANS!!!
your call. please stay safe on heights.
I've seen many attic ladder failures, it is not pretty and never espected until you are laying looking around wondering wth happened
Old 02-17-2014, 01:55 AM   #26
Rewards Points: 24
You may want to think a little on insulation and ventilation in the attic because of the heat that may rise during the day/summer/hot periods. When it comes to storage, it's important to control the humidity and dampness level for items that you'll be storing there for long periods of time during the year. Have a think on what you may put up there. That will give you an idea for how much reinforcing and adjustments you may need to do.
MarkSindone is offline   Reply With Quote
Tags
attic , joists
Insulating unvented attic w/ 2x4 rafters? rion.martin Insulation 6 04-27-2014 06:43 AM
Creating a working space helpinggirl General DIY Discussions 10 11-14-2012 08:18 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
Looking to utilize attic space - questions dwoloz Building & Construction 5 08-05-2010 07:35 PM
