Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-17-2006, 09:45 AM   #1
creaky stairs
I'm in a 60 year old row home. The steps from the first floor to the basement squeak loudly. what can be done to silence them or lessen the sound/movement? Structurally there is no problem, just irritating on us because of the noise.
Any ideas?
Thanks.
Harry
Harry is offline   Reply With Quote
Old 07-17-2006, 03:33 PM   #2
creaky stairs
Find the squeak. Then either nail the section down, screw the section down or if it is near the stair stringer then glue it down. You could also insert a small piece of wood shim to take up the space. The reason the the stair squeaks is because the wood has movement and is rubbing against another piece of wood or other object. If you can stop the wood from moving then the squeak should diminish.
redline is offline   Reply With Quote
Old 07-17-2006, 07:54 PM   #3
creaky stairs
Thanks Reds
Old 07-23-2006, 10:46 PM   #4
creaky stairs
More On This Topic
Hi this is Kimo Greene, I'm here to teach you how to shape a surfboard on behalf of Expert Village. The stringer is basically for strength. Without a stringer, the foam is very flexible, you can, like, bend it like this. And that's exactly what will... Read More »
Hey this is Hugo at Expert Village and this section that you are watching now is on duck identification. When you are hunting ducks you want to be real careful at knowing what ducks are that you are shooting at. Being able to identify drakes and hens... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how we will cut the stringers for the sides. Now that our sawhorses are standing, we are going to add some stringers along the side for stability purposes. Now we are... Read More »
Ok, now let's look at what is the Chinese word for stairs, lou ti. In this Chinese word actually ti means stairs and lou, the meaning of lou is building. Stairs in a building that's lou ti, stairs in Chinese. We know that lou contains this wood radical... Read More »
Hello! My name is Mac. On behalf of expertvillage.com, I am here to continue our discussions on shielded metal arc welding or stick welding as it is commonly known. Up to this point we have covered how to strike an arc, how to run a stringer bead, how to... Read More »
Changing from carpet stairs to wood stairs DIY_user Carpentry 14 11-15-2009 11:09 AM
Railing on Stairs Melanie337 Carpentry 6 10-04-2006 10:39 AM
drywall on stairs goodman Carpentry 11 03-20-2005 11:45 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
