Cracked Wood Frame Door. - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 11:56 PM   #1
Cracked wood frame door.
I screwed in a temporary wood block to prevent the door from opening.
I know its a stupid way.'
http://www.flickr.com/photos/23636401@N04/4149488934/
How would you guys fix this?
StevenH is offline   Reply With Quote
Old 12-01-2009, 07:08 AM   #2
It looks like the hole was drilled off center, correct?? Measure the hole, find a hardwood dowel that fits tightly , glue in the dowel(TitebondII), wait for glue to set up, sand where needed, redrill hole in proper place.
Old 12-01-2009, 02:54 PM   #3
Yes, you are correct. I'm a bit confused .You said a dowel (round wood)???
Old 12-02-2009, 07:23 AM   #4
Yes, round wood, preferably a hardwood, available at home, hardware stores, and lumberyards. Your hole is probably 7/8" or 1". You might smooth out the hole to the next size and use that size dowel. And use a drill bit with a starting point when you redrill, it will help keep the bit running straight.
Old 12-02-2009, 11:59 AM   #5
Household Handyman
Rewards Points: 1,408
Your pic is posted but I wish it had been taken from a little further back. First: Is that a picture of the door or the door jamb? It appears to be the door jamb and is drilled for a dead bolt to set into when locked. But it doesn't look wide enough for a door jamb. I think this will work for either one:
It appears that a section of wood, approximately 1/4"-3/8", has broken out where the 2x4 is now located, so I'm going on that theory. Bill's idea is good, if not for the supposed missing piece. Hmmm, the door is wood, and painted, so from experience: You have a couple of choices, 1)- Make a piece to fit the broken out area to glue back in, then do what Bill suggested. Or 2)-Cut out an area which would include the broken out area and the hole, cut a new piece of wood which will fit into this cut-out area snugly and glue back into place. After the glue is fully dried, sand all surfaces flush, re-drill your hole as needed, and paint as needed. Good Luck, David
Old 12-02-2009, 06:57 PM   #6
Rewards Points: 1,520
You could just screw the door shut I would think (into door face into door jamb) but:
1. Screw holes to fix later (not such a big deal if painted)
2. No exit if a fire breaks out (could be a big deal).
bob22 is offline   Reply With Quote
wood piece underneath front door sill llckll Flooring 1 08-25-2009 07:12 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Door frame against stone wall elliowb Carpentry 8 12-14-2007 05:03 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 12:00 PM
