-   -   Crack/Split right under door knob? (http://www.diychatroom.com/f14/crack-split-right-under-door-knob-159849/)
syshee 10-12-2012 01:13 PM
1 Attachment(s)
Long story short, I locked myself out of a key locked room and ended up crowbarring my way in. Since the key is gone, I decided to replace the knob with a basic bathroom lock. However, by doing so, I split the wood under the door knob. Is there a way to fix this without taking the wood off its hinges? I've got paint of the right color, sandpaper, wood glue, and probably a clamp somewhere, but I'd like to avoid taking more things apart. I've attached pictures of what I'm dealing with.
kwikfishron 10-12-2012 05:02 PM
199 Attachment(s)
The problem with gluing that up in place is controlling the mess. You’re far better off removing the hinge pins and laying the door flat, injecting some Titebond 2 glue, clamp and let it sit overnight. If the split was on the top side it would be a different story.
PaliBob 10-12-2012 05:33 PM
Thanks for the pic. Looks like a job for Gorilla Glue
and a deep throated C Clamp. This one would work.
  • Force the crack open as wide as possible to accept the maximum amount of glue
  • Use thin pieces of wood under the clamp to protect door surface
  • Let dry for 24 hours
Maintenance 6 10-16-2012 11:26 AM
Use some wax paper against the door after you glue it so your blocks don't glue themselves fast to the face of the door.
SeniorSitizen 10-16-2012 12:32 PM
Good grief, C clamp, Gorilla glue, tite bond . Don't bother looking for your clamp. Elmer's school glue with a chair leaning against it for 30 minutes will fix that .
PaliBob 10-16-2012 12:41 PM
Originally Posted by Fairview (Post 1032022)
....Elmer's school glue with a chair leaning against it for 30 minutes will fix that
Wow! If that works you are the DIY King.
woodworkbykirk 10-16-2012 02:56 PM
if its a hollow core just replace the door.. when stuff like that happens the repair hardly holds up long term
