Covering Stringers With Azek - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 08:51 AM   #1
Rewards Points: 89
Covering stringers with Azek
Looking to cover existing deck stair stringers with Azek or Veranda board to give it a nice finished look.
Long run of stairs (11 steps),fairly uniform 7/11 rise/run.
Question,Cheapo Depot sells a 5 and a 6 stair riser kit,do you think its possible to use those as a template to cut the Azek,then fit it up to the stringers?
The stairs are seperated between the 5th and 6th step by a post,which will also need to be covered.
spring3100 is offline   Reply With Quote
Old 07-29-2013, 03:49 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
just cut the level and plumb cuts on the azec so it can be tacked in place on the side of the stringer then trace the stringer notches in place. cut and nail off
woodworkbykirk is offline   Reply With Quote
Seeking AZEK Decking Project suggestions bobinchico Building & Construction 0 09-26-2012 01:37 AM
Fastening Azek Trim joetab24 Building & Construction 13 08-15-2011 07:23 PM
Deck: how to attach stringers 10Thumbs Building & Construction 6 06-08-2011 01:35 PM
Attic Steps, Perpendicular to Stringers mok Building & Construction 4 04-21-2011 07:25 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 08:48 PM
