Have tried stopping the water leak where the covered deck meets the mobile home. Been leaking since I built it a long time back.
Has also caused a short in the wall from where I installed a covered outside outlet a long while back but got that fixed.
Have tried black roof cement & silicone with a piece of tin running across it but won't stop it completely.
Have heard that sticky tape suppost to work great but how do you apply it with all those ridges on the top roof panel's?
Was told you have to apply the tape then apply the rubber cement over that.
Have some seams on the roof too that need to be sealed as well using the tape but that shouldn't be a problem applying it to that since it's flat.
It's a v-roof design roof.
Need to get the darn thing sealed before the hard winter creeps up on me this winter.
Made the mistake when I connected it too low at the edge of the mobile home with a 2x6 runner. Water causes a puddle along the lenth of it.
It's a 12 X 16 ft. porch & does have a 12 degree slant to let the water run off it.
Thank's for any tips on sealing it properly would be nice.
Looks like a big mess now with all that black roof cement on it.
David:wink:
David:wink:
