Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-25-2008, 10:52 PM   #1
cove molding mitering
I would like to know how to properly miter cove molding for both inside and outside corners
MikeBaker is offline   Reply With Quote
Old 10-26-2008, 12:41 AM   #2
Moderator
Termite's Avatar
You can miter it on a miter saw or in a miter box, depending on what you have. For 90 degree outside corners, set your saw at 45 degrees. Pretty easy.
For inside corners, ideally...You cope them with a coping saw. If that's something you're not up for, then you just miter them at 45 degrees.
You always set your saw to half of the wall corner's angle. If the walls aren't a perfect 90 you just have to adjust.
Old 10-26-2008, 08:39 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
pay attention to the profile of the cove, there is usually a wider profile at the top. when you install the first piece just make sure you keep them all the same. You will be surprised how many people don,t realize this. BOB
Also remember when you cut the pieces in a miter box ,place your material upside down and backwards. this way you can't go wrong.
Old 10-26-2008, 10:08 AM   #4
my 2 cents, I'd practice the cuts on some scrap, didn't help me, (I'm terrible carpenter) but once you cut a length wrong, you have some too short to use costly scrap.
DUDE! is offline   Reply With Quote
Old 10-26-2008, 03:56 PM   #5
Drywall contractor
DUDE! has good point.....get a few extra feet for sure. If it's sold by the foot at the big box stores, they'll take it back if you have leftovers.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
How do you remove plaster cove molding? mattedfred Remodeling 3 10-28-2008 04:48 PM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 02:49 PM
Cove molding: to cope or not? white29 Carpentry 24 02-11-2008 12:33 AM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
Baseboard molding tiled in... Donald Lynskey General Discussion 1 07-07-2007 07:47 PM
