Cove Molding: To Cope Or Not? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-22-2008, 08:34 AM   #16
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
We have one of these:
http://www.collinstool.com/base.php?...oping_foot.htm
Video: http://www.collinstool.com/base.php?...os.php&t=0&r=2
- Build Well -
Old 01-24-2008, 03:05 PM   #17
Thats a neat lil saw, I've used a sabre and an angle grinder with good results after some practice, angle grinder works great on crown.
On simple bases or coves I use a hand saw, find coping alot faster and neater than miters. But a miter saw and a 5 gal bucket of caulk works too.
Grandpa showed me how to cut my first cope and scarf almost 40 yrs ago, bet they're still tight today.
cnydave is offline   Reply With Quote
Old 02-10-2008, 11:08 AM   #18
Rewards Points: 49
I am trimming out base which is about 6". I have to cope all inside corners to get a good fit. I am also having trouble with the outside corners at a 45 degree. It seems that the corner bead kicks the cuts out. Does anyone have any suggestions?
worker903 is offline   Reply With Quote
Old 02-10-2008, 12:21 PM   #19
Cope like the Pope on dope.
Rock is offline   Reply With Quote
Old 02-10-2008, 02:29 PM   #20
Custom Cabinet Maker
Worker: overcut to about 50 degrees.
skymaster is offline   Reply With Quote
Old 02-10-2008, 05:30 PM   #21
Rewards Points: 49
Skymaster, I don't quite understand what you mean. The max the saws are set up for is only 45 degrees.
Old 02-10-2008, 06:59 PM   #22
Get a "Coping-Stretcher"....
- Build Well -
Old 02-10-2008, 07:34 PM   #23
Is that next to the drywall stretcher?
jerryh3 is offline   Reply With Quote
Old 02-10-2008, 07:49 PM   #24
Actually, I believe they are in between the Plywood Stretchers and the Sheetrock Stretchers ....
- Build Well -
Old 02-10-2008, 11:33 PM   #25
Right across from the brass magnets..........
ewils91 is offline   Reply With Quote
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 07:11 AM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 10:12 PM
Installing Crown Molding fmolden Carpentry 6 01-08-2008 10:09 AM
Make youre own dentil molding? vendejp Carpentry 4 10-03-2007 11:55 PM
Baseboard molding tiled in... Donald Lynskey General DIY Discussions 1 07-07-2007 06:47 PM
