Couple Questions On Installing Real Wood 4x8 Beadboard Paneling (Georgia Pacific) - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 10:28 PM   #1
Rewards Points: 117
Question
Couple Questions on installing real wood 4x8 beadboard paneling (Georgia Pacific)
PLEASE DELETE.... rewording /reposting question. Thanks
RickDel is offline   Reply With Quote
Old 07-06-2010, 07:29 PM   #2
Rewards Points: 5,336
Adding to the wall requires extending the door and window frames so the beadboard butts up against the frame and doesn't cover it leaving a raw edge.
The sills and aprons don't get installed over the moldings.
Ron
Old 07-06-2010, 08:11 PM   #3
Rewards Points: 117
Ron, I'm not sure I follow..... Are you saying I should build up my casings so they extend out beyond (proud) the chair rail? Then butt the chair rail up to the casing? My top cap is 1 1/2" wide, that's why I was planning to overlap the top cap and butt the chair rail. Is this an acceptable way of doing a return?
As for the exposed edge. There's no casing around the closet. If there were I could just butt the beadboard up to it; however, there's not and I have a light switch preventing me from adding any. So, since there's no casing, how do I end the beadboard??? I've only seen a piece of corner trim used to cover the edge, but since my sliding closet door shuts flush I don't think I can use the corner molding. So, is there an alternate way of ending the beadboard so it looks good?? (bevel the edge, use caulk..... anything you guys have seen that looks good?)
Old 07-06-2010, 08:45 PM   #4
You would pull the casings off the wall and extend the window frame. If the doors have no casing, take a 3/8" lath molding and frame the door. Butt the paneling up against it. If the connection looks wavy, install casing around the door. You can extend the switch box to be flush with the new panel plane.
Ron
Old 07-07-2010, 02:46 PM   #5
Rewards Points: 117
I get it now.... thanks Ron!
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Installing Beadboard paneling Sannikay55 Remodeling 1 09-18-2009 04:38 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
couple questions about installing phone jacks joeyboy Electrical 31 10-09-2007 02:26 PM
