Countertops. - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 09:13 PM   #1
countertops.
I have a 18 inch bartop to install on a 2*4 wall. Just regular formica with an overhang, the tops come with a 3/4 inch lip around them, so I was going to cut a piece of 3/4 ply the shape of the under side of the top, and then screw it down to the 2*4 place the top on and screw the ply to the top from underneath. Now the question is with the 15 inches hanging over what would be the best looking and strong enough way to hold up the overhang. Thought about just putting some crown under there.
Toolmaster is offline   Reply With Quote
Old 06-03-2009, 04:13 PM   #2
Rewards Points: 5,336
You'll need a lot more then crown molding to keep it up. It should have at least a 6"-8" support under it to keep it from collapsing under inordinate weight. Like your son sitting on the edge.
Ron
Old 06-05-2009, 06:58 AM   #3
Old School
cabinetman's Avatar
Originally Posted by Ron6519 View Post
You'll need a lot more then crown molding to keep it up. It should have at least a 6"-8" support under it to keep it from collapsing under inordiate weight. Like your son sitting on the edge.
Ron
Absolutely. What's needed works like a gusset. They can be made easily, or purchased. They may be called "brackets" or "corbels".
cabinetman is offline   Reply With Quote
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 08:32 PM
Need advice/tips on tearing out old laminate countertops TumsGum Kitchen & Bath Remodeling 6 03-07-2009 10:52 AM
Opinion on countertops please... skipjack Kitchen & Bath Remodeling 11 01-29-2009 12:20 AM
Which saw blade for laminate countertops? Proulx06 Carpentry 5 01-15-2008 09:45 PM
