Counter Top - Cracked Laminate - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-13-2010, 05:40 PM   #1
Question
Counter top - cracked laminate
While installing my new counter top I pushed it back a bit to hard and it cracked the back piece laminate (the piece that goes up against the wall right in the corner where that back piece meets the flat counter)... its not totally broken off... just the laminate cracked in about a 1 foot piece of the counter right in the corner of where the counter meets the back piece that goes up the wall (I dunno what the name of that piece is
looks like this: (the counter _________| <--wall part).
Laminate Break in this corner part
Is there some way to "Glue" the laminate back or put some kinda clear seal to seal it back together? Either that or I guess thats where my toaster will go to hide it
any ideas?
sleepysmurf is offline   Reply With Quote
Old 08-13-2010, 06:53 PM   #2
Rewards Points: 5,336
Cracked laminate will compromise the substrate. Hiding the crack will not protect the waterproofing. If it's far away from the sink you might be able to salvage the installation.
Ron
Old 08-13-2010, 07:03 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
All HPL brands make a seam filler that will match your counter top and the seam filler will seal it from water. I don't know the color you have but maybe the seam filler will work for you.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Laminate Counter Tops, clear coat? joedreamliner787 Painting 9 06-16-2011 03:55 PM
Cutting Plastic Laminate counter top edge (hot bit roller) Steamer2 Remodeling 2 04-01-2010 06:41 AM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 11:53 AM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 06:34 PM
Repairing scratch in laminate counter Keyo77 General DIY Discussions 2 02-03-2008 01:00 PM
