Counter Top - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-07-2012, 05:30 PM   #1
counter top
I have never reaplied new p/l over substrate that has had old p/l removed. Will the new p/l lay down smooth or will I have problems? What is the best way to remove most of the old glue?
lee4493 is offline   Reply With Quote
Old 12-07-2012, 05:49 PM   #2
Rewards Points: 13,270
If your talking about applying a product like Formica you would be so much better off just removing what you have and make all new ones.
Reasons being:
Extremely hard to line it up when trying to place it, once the material touchs it's near impossible to more it to realign it.
Very hard to trim the edges where it comes close to the walls.
Why take the chance of it not sticking.
The laminite needs to make 100% contact with the surface below.
Old 12-08-2012, 07:56 AM   #3
Rewards Points: 494
You can apply new contact cement (use the flammable kind) over the old.
Acetone will dissolve the cement. You can squirt acetone into the gap between the laminate and substrate, continuing to squirt acetone and lifting up laminate, to remove the laminate if you happen to make mistake aligning them.
Having said it, work will be easier, dust control better and finish more exact by removing the substrate, if it was installed as a removeable.
Don't try to sand the old glue. Feel around and scrape/dissolve any speck or spot that feels different from the rest.
carpdad is offline   Reply With Quote
Old 12-08-2012, 08:11 AM   #4
If any acetone is used keep in mind it's extremly flamable!
No smoking, cut off any gas pilot lights in that area.
Would you butt or miter a butcher block counter top if... Big-Foot Kitchen & Bath Remodeling 15 12-13-2012 03:38 PM
Receptacle dreed Electrical 8 12-21-2011 01:56 PM
Cutting Counter Top sleepysmurf Carpentry 3 08-14-2010 12:16 AM
Pop-up Kitchen Counter Receptacle paredown Electrical 11 03-12-2010 12:58 PM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 12:53 PM
