Correct Saw Blade - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 03:29 PM   #1
Correct Saw Blade
What would a good choice be for a 10" sliding compound mitre saw blade for cutting 13 one inch varnished hard maple stair treads to get a good clean straight cut but to avoid splintering? Any recommendations? Thanks so much!
Melanie337 is offline   Reply With Quote
Old 12-07-2009, 04:34 PM   #2
Remodeling Contractor
Use a Freud 80 tooth blade
Old 12-07-2009, 05:25 PM   #3
Civil Engineer
Rewards Points: 4,854
I recommend carbide tipped blades, typically last a lot longer than steel.
Old 12-07-2009, 06:22 PM   #4
...so, 80 tooth carbide tipped should do the trick. Thanks! M
Old 12-07-2009, 06:55 PM   #5
DIY staff
Rewards Points: 7,174
You are going to like the cut!!!
Old 12-07-2009, 08:32 PM   #6
She will like the cut of the "Freud"...is that what you mean?
BumperCrop is offline   Reply With Quote
Old 12-07-2009, 09:08 PM   #7
An 80 tooth blade gives a smooth cut on a chop saw. That is what you will like. Feud is just a quality blade. And the carbide tipped blades will last longer as posted.
Old 12-08-2009, 08:20 AM   #8
Home Remodeler Wannabe
Scotsman's Avatar
Would an 80 tood blade be a good blade for trim work as well as say 2x4's?
have a 10" sears craftsman, (donated unknowingly by my father) Needs a new blade, (been passed around the family for different projects) will eventually be putting up Craftsman style trim (varying degrees of flat stock).
Sorry for hijacking your thread!
Scotsman is offline   Reply With Quote
Old 12-08-2009, 09:45 AM   #9
47_47's Avatar
Rewards Points: 62
Scotsman, get yourself a minimum of 2 blades. One approx 80 tooth for trim and one 40 tooth for the rest of your cross cuts.
To the OP, the 80 tooth Freud will give good results. Adding an auxiliary zero clearance fence to the saw will also help for straight cuts. It will reduce the chance of splintering at the back of the cut and also an aid in locating the blade to your cut line.
47_47 is offline   Reply With Quote
Old 12-09-2009, 01:27 AM   #10
Wood Butcher
robin303's Avatar
Bingo
robin303 is offline   Reply With Quote
Old 12-19-2009, 08:30 PM   #11
The job is done. The 80 tooth Freud was definitely the right choice...although the only one I could find was a thin kerf type...but I don't think flexing was a problem in my case. Thanks all !!!!!!!!!!!!!
Best blade for circular saw to cut multiple layers. Clutchcargo Building & Construction 5 12-02-2009 07:27 PM
How do I pick the correct coaxial cable? fwmcbigfoot Home Theater 1 12-30-2008 09:45 AM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 08:08 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 03:29 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 06:58 AM
