Correct/Preferred Jack Rafter Orientation? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 09:52 AM   #1
Rewards Points: 282
Correct/Preferred Jack Rafter orientation?
This is a view looking down on a U-Shaped patio roof addition. It will be a shed style roof tied into the sides of 2 gable roofs and the long main roof.
Rafters will extend for the roof ledger to the patio beam.
Which side is correct for the rafters in red? Left or right?
Multiple short jacks to the side ledgers or same orientation as the common rafters?
Thanks!
jcrack_corn is offline   Reply With Quote
Old 04-12-2011, 02:32 PM   #2
Old School
Willie T's Avatar
Are these all to be on the same 'plane'? In other words, one flat sloping surface? Not three surfaces, one sloping away from the house, and the two smaller sides ones sloping to the left and to the right.
Usually it is done as you have the multiple ones on the right. But either will work... although the long spaces between the ends of the ones on the left will reduce the strength of what the plywood could support along that angle.
Admittedly, this is a sloppy drawing below, but is this about what you're trying to achieve?
Correct/Preferred Jack Rafter orientation?-shed-between-gables-1.jpg
Willie T
Old 04-12-2011, 11:18 PM   #3
Rewards Points: 282
yes, your drawing is spot on, it will be a flat sloping roof. everything on the same plane.
i figured the ones on the right were correct, but just wanted to make sure there wasnt some funky reason to NOT put those short jacks or braces perpendicular to the common jacks.
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 10:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 11:40 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
Phone/Fax Wall Jack cmgith Electrical 5 04-18-2009 11:21 PM
