Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-11-2011, 08:30 PM   #1
Cornice Boards
I would like to make cornice boards for 4 windows: 2 each in living & dining rooms and I want decorative wood. I would like them to extend 4-5 inches from the wall and be approximately 7" deep. (They are expensive to order & you
only see the catalog pictures from Penney's & Lowe's. Because they are special order, you cannot return). Can I make them from the crown moulding which is readily available?
Maggi is offline   Reply With Quote
Old 11-11-2011, 09:34 PM   #2
Cornice Boards
If you have the ability to make the necessary cuts, you can make them out of just about anything. Crown molding and some 1x flat stock would work. The hard part is going to be the miter cuts on the detail work.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 11-13-2011, 09:22 PM   #3
sdsester's Avatar
Cornice Boards
Might see if someplace like this has what you are looking for. There are others on line. If you are going to paint it and are not a purist, the extruded foam might work also. Search online. As mentioned, you still need to figure out the miter cuts at some point.
http://www.wishihadthat.com/crown-mo...FdBrKgodsgehMg
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
MikeKy55 (11-13-2011)
Deck Boards and Deck Size Earnie Building & Construction 6 09-12-2011 09:38 PM
Gate post ledger boards Klawman Building & Construction 5 04-14-2010 02:22 AM
how to lay 3-strip boards so the ends don't look strange conradA Flooring 3 03-01-2010 09:12 AM
How to attach cornice boards to the wall molster Interior Decorating 2 10-29-2008 06:21 AM
hardwood flooring boards matjone Flooring 4 02-01-2008 06:35 PM
