Corner Shelves - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-04-2008, 02:31 PM   #1
corner shelves
I am trying to add corner shelves in my closet and am not quite sure how to create the shelving to unsure it is usable.
sanchez is offline   Reply With Quote
Old 09-04-2008, 05:59 PM   #2
Not sure what you would like to do?
is this clothes closet? a walk-in maybe? do you want to extend existing shelves (add)? what is there now?
Make a triangular wood corner shelf unit?
Big Bob is offline   Reply With Quote
Old 09-04-2008, 06:41 PM   #3
thanks for the reply. It is a walk in closet that is basically square. I was trying to make the corners, both, shelving for folded clothes. So I guess it would be a triangular shape in the end.
Old 09-04-2008, 07:23 PM   #4
Registered User
Termite's Avatar
Cut the shelves from plywood, MDF, or a 3/4" thick wood material of your choosing. Then mount 1x3's horizontally to each wall (try to hit studs or use drywall anchors) from the corner to support the shelf.
Old 09-04-2008, 07:25 PM   #5
Registered User
Termite's Avatar
Or for a less permanent and more adjustable installation, there are many metal standards and brackets available at home centers. They simply screw to the wall. You'd need one at each corner of the triangle, more if the shelf is huge.
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 01:35 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
