Coping Crown Molding In So Cal - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 01:22 AM   #31
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The technique that Gary uses is to apply very little pressure when either pushing or pulling the jigsaw but to get most of the cutting action by rocking the blade back and forth against the moulding. In this way with an aggressive blade, more material is removed, but the blade can be held closer to the cut line with more control.
The other tip is to use the finger tips of your second hand to help steady and quide the saw. This technique may not be possible without a barrel grip Jigsaw.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 12-08-2009, 02:17 AM   #32
Rewards Points: 866
I don't doubt that you are right about having better control with a barrel grip jigsaw, but while I am keeping an eye out for a good deal on one, it isn't on the list of priorities for the time being. Speaking of tools, I rediscovered the second power tool I ever owned. My old circular saw. It makes mince meat out of plywood panels to large for my little 10" bench saw, which has no extension wings or overflow panels.
Klawman is offline   Reply With Quote
Old 12-23-2009, 03:51 PM   #33
Rewards Points: 866
Almost coping
I think I am starting to get this coping down pretty well, although it takes me a long time. The below was done with a cheap old jig saw, with the foot removed to allow me to try to guide it along the cope.
This is without sanding with the Dremel. I still don't quite understand how to handle the top and bottom. I think I can figure it out. My plan is to first cope one end of each piece and then make the but cut on the far end. Then, if I screw the pooch, I can recope it without wasting an entire board.
Coping Crown Molding in So Cal-pict0004.jpg   Coping Crown Molding in So Cal-pict0001.jpg
Tags
collins coping foot , coping , easycoper
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
crown molding and chair rails hollyjo213 Kitchen & Bath Remodeling 2 10-02-2009 01:56 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
crown molding ponch37300 Carpentry 15 06-05-2009 03:35 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
