Coordinating New Door Threshhold With Flooring - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-28-2011, 11:52 AM   #1
coordinating new door threshhold with flooring
I'm installing a new pre-hung door along with the rest of the non-load bearing exterior wall (there's an existing beam supporting the roof that I'm not going to affect). I've attached a picture (photo 1) of the edge of floor that I've built up by about 9" or so. I'll be hot-mopping it for water-proofing before installing the wall sill plate and door as seen in the photo 2. The issue is, in photo 3, one can see the base of the inside face of door which is up about 1-1/2" thanks to a piece of 2x4 composite material. My flooring to go on top of my sheathing is only 1/2"-thick which would leave about an inch of drop from the threshold down to the finish floor surface! Is this normal and, if so, how is it accommodated? With a big piece of trim?!
coordinating new door threshhold with flooring-photo-1.jpg   coordinating new door threshhold with flooring-photo-2.jpg   coordinating new door threshhold with flooring-photo-3.jpg
muncher is offline   Reply With Quote
Old 05-28-2011, 11:54 AM   #2
photo order
After posting, I noticed that the photo order is off. The first picture is actually "photo 2", the middle picture is "photo 3", and the last picture is "photo 1".
Old 05-28-2011, 10:44 PM   #3
Rewards Points: 5,336
You should be able to pick up a sloped threshhold to reduce the height. Andersen used to carry these to use with their Patio and French doors.
Or you can fabricate one yourself that matches the floor species.
Ron
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
basement flooring suggestions? jeffro83 Flooring 2 05-14-2011 12:58 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
