"Converting" Carpeted Stairs To Hardwood Stairs. - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 05:50 PM   #16
Rewards Points: 528
You were told earlier that if you put wood on top of current steps you bottom step will increase beyond the acceptable rise. The top step will shrink.
By doing this you will make the stairs not code compliant at all.
Suggest either to just refinish existing or tear out and start over.
Do you have access to the stairs from below?
I just sanded some existing treads and my customer refinished them and they look very good.
framer52 is offline   Reply With Quote
Old 03-23-2013, 05:50 PM   #17
Dave88LX's Avatar
Rewards Points: 564
Originally Posted by joecaption View Post
Where's the ballister, and how do you plan on adding a rail with it built like that?
That's something that has plagued me since I moved here.
Remember me? I'm this guy:
Have a railing project to do; split foyer home.
Still working on figuring out how I'm going to do that.
Dave88LX is offline   Reply With Quote
Old 03-23-2013, 05:54 PM   #18
Dave88LX's Avatar
Rewards Points: 564
Originally Posted by BigJim View Post
Just my two cents, I would scrape and refinish what is there now, I refinished some a couple of years back like your's and they turned out looking good.
They are horribly beat up "carpet grade" (lack of better term) treads with splits, cracks, holes, paint, and gouges. What shape did those ones you did start out in?
Old 03-23-2013, 05:59 PM   #19
Dave88LX's Avatar
Rewards Points: 564
Not to be a smart-alec, but isn't the whole staircase already unacceptable at 8" vs. 7 3/4"? Also, adding the required backerboard + thinset + tile on the bottom landing will raise lower that height back to the same as the rest, no?
Top step rise will go from 8 1/2" to 7 3/4".
They already aren't. There is NO way to make them code compliant besides as you suggest below, tearing out and starting over. This is not a timely or cost-available option unfortunately.
I have access from below, if I pull out the AWESOME drywall work the previous homeowner did...why do you ask?
Old 03-23-2013, 06:02 PM   #20
Rewards Points: 630
as long as you are adding the same flooring to al the steps and landings your riser height would stay the same. so in that case i would cut off nosing flush with riser.
scribe in new skirt boards which will cover the old skirt board. http://www.thisiscarpentry.com/2011/...-skirt-boards/
use the same flooring you are using on floor use it on the riser and treads with the matching stair nosing piece
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-23-2013, 06:05 PM   #21
Rewards Points: 13,266
Any reason why when you built that wall on the right hand side of the steps and left all that flooring exposed?
Old 03-23-2013, 06:08 PM   #22
Dave88LX's Avatar
Rewards Points: 564
Whoa whoa, first let me make it clear I had *nothing* to do with the construction or design of this house.
Are you talking about the picture with the couch in it? Or which are you talking about?
Old 03-23-2013, 06:25 PM   #23
Dave88LX's Avatar
Rewards Points: 564
I'm currently at 33" width. Code is calling for 36", I'm already 3" short on the width. Stupid house. What is the intention of the second skirt board; to fill in the holes that cutting off the tread overhangs will leave?
Old 03-23-2013, 06:44 PM   #24
Rewards Points: 630
yes and you can use a 1/4 plywood or a veneer to do so will not shrink steps much.then cap top of skirt board to cover veneer.
also you have to keep in mind code when house was built is different from today. i would put railing at top floor and leave open between flights due to it probably being grandfathered in. but if you choose not to you could put newel at landing run hand rail up into the wall and add spindles that would attach to skirt board. but i do not believe it would ever look right.
Old 03-23-2013, 06:47 PM   #25
Dave88LX's Avatar
Rewards Points: 564
Oh I definitely need to put a railing up between them. I still have kids, I don't want them toppling over the edge. Or my dogs thinking they can jump over. That link didn't work, but skirt boards seem to be a PITA to make. Then again, everything seemed like a PITA until I tried it.
Nothing will ever look right on that stairwell because of the stupid angled wall.
Old 03-23-2013, 06:58 PM   #26
Rewards Points: 630
it is at this web site and it gives an easy way to do so
Old 03-24-2013, 09:25 AM   #27
Rewards Points: 196
Since you said you wanted to paint the stringers and risers I would leave those intact. Putty or bondo the knots and then primer them before painting. The treads I would remove and replace with your hardwood ones keeping the nosing at 1 1/8" and tread depth at 10". Only problem is your 8 1/2" per rise. I could understand that rise IF your treads were deeper, say around 11" instead of 10". Anyways if you wanted to convert the left side to an open you can remove that stringer and install a cut out open stringer. Run your risers edge flush with the outside edge of the stringer. Run your treads 1 3/8 longer than what they currently are. Reason for the treads being that much is because you will be installing a return miter on that end. 1 1/8" is what your nosing is but I said 1 3/8". The extra 1/4" would be so you can also install tread brackets which would slip in behind the back end of the return (reason for that 1/4" gap) and those brackets will cover your end grain of the risers. You can also go with routered returns which means you would have your treads flush with your risers (and stringer) and still cover the end grain of your risers but then youll also see end grain on the front of your tread returns.
Jason34 is offline   Reply With Quote
Old 03-24-2013, 12:13 PM   #28
Roofmaster
Rewards Points: 2,172
This one is a no brainer to me. This whole staircase is very accessible. Order a new staircase with oak treads directly from a millwork, take out the old, and put in the new.
Old 03-24-2013, 03:49 PM   #29
Rewards Points: 196
When measuring the width of the stair (out to out) you measure from outside of the stringers not the inside of them. So if the inside of your stair is 34" then you meet the 36" code.
Old 03-24-2013, 09:52 PM   #30
Dave88LX's Avatar
Rewards Points: 564
Did not know this, thanks!
What would the estimated cost of that be ball park? Hundreds? Thousands?
Please don't take this the wrong way. I know there's the right way and wrong way to do things...The thing is, we are about $50K upside-down in this house (Bought in 2007 before the bubble popped). Going to rent it out, and buying another house that's not a cluster, that doesn't need everything to be remodeled, for a lower monthly payment. This house is a sinking hole of money. I don't want to put any more money into it than necessary. If I was going to live here, I would absolutely pull the stairs out and have them done new. This isn't an option though in this case. They need to be "nice enough to rent." I DO appreciate all of your opinions though.
Hardwood or Carpet on Stairs? RugbyLove Flooring 3 11-16-2011 04:19 PM
Carpet upstairs with hardwood stairs ... what to do with top stair? jmai14 Flooring 3 09-10-2011 09:57 PM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
hardwood floor to carpeted step transition DIYguy2000 Carpentry 7 11-06-2009 01:09 PM
Hardwood & Stairs budcam Flooring 4 09-16-2009 12:12 AM
