Converting Basement Stairs To Ramp Walkway - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 02:13 PM   #1
Converting Basement stairs to Ramp walkway
I know the code for building a ramp inside the house, but I am looking for plans on how to do this. The basement is stipped down to the studs so I can literaly build any type of ramp.
The ramp is not really for a wheel chair access but for my future wife who can not walk up steps without extreme pain.
Senathon is offline   Reply With Quote
Old 05-07-2013, 05:19 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
what is the difference in floor heights? An accessible ramp is 12" in length for every 1" of height (2009 IRC will allow 1:8 instead of the normal 1:12 under difficult conditions). Most codes require a minimum of 80" of head room ....... may want to check out an electric lift depending on height, many times you can find used ones fairly inexpensive.
don't know if you'll find plans online. I typically build ramps with 2x8 joists at 12" o.c., spans are based upon wood species and grade and loads on the ramp.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-07-2013, 09:24 PM   #3
Roofmaster
Rewards Points: 2,210
I was going to say. I think you will end up with a slide, not a ramp. Really sorry for your wife. Pain is not fun. My wife and I both have Arthur and other stuff. Sucks, and no doctor wants to give you the meds you really need.
Tags
ramp
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 05:33 AM
Basement Stairs (Canada, ON code?) SFX Group Building & Construction 12 10-29-2010 04:30 PM
Basement Stairs Question callmevo4short Building & Construction 3 01-19-2010 08:11 PM
