Converting 24" On Center To 16" On Center - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 12:56 AM   #1
Converting 24" on center to 16" on center
Hello all. Thank you in advance for your help. I'll keep my question quick and to the point.
I am converting a 15x30 room that's attached to my father-in-law's shop into my wife's photography studio. The room has already been stripped to the frame where it's revealed it's 24" center and saw mill grade studs. I have an idea to insulate this existing stud wall and bringing a new stud wall up right in front; nice and square and with a 16" on center. Like I said, it's only use will be for photography.
I can send some photos if it helps with the painted image. And of course I can provide as much needed detail as . . . well as needed of course.
Thanks again for helping out.
newbie731 is offline   Reply With Quote
Old 02-19-2011, 05:12 AM   #2
what is the purpose of doing this? If you have to have 16"oc, why not install horizontal firring strips over existing wall?
mrgins is offline   Reply With Quote
Old 02-19-2011, 05:23 AM   #3
Interesting thought.
As a self-proclaimed "newbie", AKA "DIY'er" I am certainly open to suggestions. This is an idea that I've yet to explore but I am definitely interested. Can you explain in a little more detail please?
Old 02-19-2011, 05:30 AM   #4
Sure. Use 1x3 horizontally across the face of your existing studs. This will thicken the wall by 3/4" so you'll need to build out any door frames by the same amount. Position the 1x3 at 16"o.c. I use actual 1x3 #2 pine as I don't like the quality of 1x3 strapping.
Apply your wall covering (drywall, paneling?) over the top.
Old 02-19-2011, 07:01 AM   #5
Rewards Points: 5,336
Seems a whole lot of work when you can just install the insulation horizontally in the 24" joist bays.
Ron
Old 02-19-2011, 05:34 PM   #6
A Little Of Everything
Rewards Points: 1,364
I'm not sure exactly what you're asking, or wanting to do. But it seems to me that you could just as well put 24" horizontal insulation in, then drywall it.
DrHicks is offline   Reply With Quote
Old 02-19-2011, 06:40 PM   #7
Yes. Very true. However the problem lies with the existing frame being uniformly inconsistent as such that it would no doubt leave the drywall looking wavy. The old studs just don't seem to run as true as today's studs. Even the old chip board that was on the walls were wavy. So I need the ability to ensure a nice square uniform frame.
Old 02-19-2011, 06:49 PM   #8
Oh. Okay, that makes sense.
Assuming I'm now understanding you correctly, I think I'd just build a regular studded wall - as you had earlier mentioned - place it in front of the rough wall, and drywall it. This is what's normally done in basements, when people want to "finish" them.
Old 02-19-2011, 06:53 PM   #9
Either shim the firring where necessary to smooth the bumps, or if it's really that bad, build the new wall
Old 02-19-2011, 08:54 PM   #10
Registered User
Rewards Points: 526
If both rooms are always heated, strapping would work. If insulation is for R-value, the strapping would leave convective loop pathways without the insulation flush to the drywall, if it be fiberglass degrading your effort; The "biggest loser" in fiberglass insulation....
Gary
Old 02-19-2011, 10:42 PM   #11
Exactly as I thought too. I was taking my cues from the basement finishing techniques I've read about. From my calculations there really isn't a price advantage doing the firring strips rather than just framing new walls. And the firring strips would actually be more time intensive given the need for shims and all.
Old 02-20-2011, 10:25 AM   #12
Actually the firring strips would be cheaper AND less time consuming but thats based on a smooth wall to start with. Sounds like you'd be better off starting from scratch with 2x4s
Old 02-20-2011, 11:43 AM   #13
Rewards Points: 1,536
Want to sister a new stud to every other old stud (to present a new straight front edge) and install two new studs (to achieve the 16 inch spacing) between every two sistered studs?
And install the new drywall quickly enough before the new studs have a chance to warp or bow as they dry out.
Old 02-20-2011, 06:33 PM   #14
Yea I think a new frame positioned in front of the old one is the best idea. Does anyone see a problem with insulating in the new stud spaces as opposed to insulating between the old 24" spaces? Precut baffles would work best between the new 16" spaces.
Old 02-21-2011, 05:32 AM   #15
If this is an interior wall between two heated spaces, then I assume you're insulating for sound. Don't use a vapor barrier
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 06:56 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 10:56 AM
Replacing wood on 24" center trusses Novar Roofing/Siding 2 04-24-2009 07:24 PM
