#1 |
Consistancy in riser height throughout a run of stairs
I know that throughout a run of stairs the smallest to the largest rise can not exceed 3/8 of an inch. My question is from rise to rise what is the greatest difference that you can have? Can you have a difference of 3/8 of an inch?
#2 |
Civil Engineer
Page 17 of the Prescriptive Residential Wood Deck Construction Guide states:
Tread and Riser Detail: 7-3/4" maximum riser; height shall not deviate from one another by more than 3/8" You should check your local code for your specific application. |
#3 |
Stair builder
You answered your own question.
The difference from riser to riser isn't the primary consideration. The max difference between the shorted riser and the tallest riser cannot exceed 3/8" no matter where they are in the flight. |
#4 |
Sounds like some lax codes in some areas. We have a 7-7/8 maximum riser with a 1/8 deviation not surpassing the max. Why not just make them all the same? It is just simple division and layout
#5 |
Stair builder
Those are from the 2006 IRC. The deviation usually occurs if the floors are out of level. If the first floor is out by over a 1/16" and the top floor is out by the same then unless you can get the BI to measure at the walk line you will be over an 1/8".
| Display Modes | |
| Questions about building stairs. | cvriv.charles | Building & Construction | 7 | 12-19-2012 05:04 PM |
| Isn't 8" riser height too big? | cvstan | Building & Construction | 30 | 07-10-2012 11:38 PM |
| stair riser height | ugabulldog | Building & Construction | 2 | 09-29-2010 08:44 PM |
| Hardwood & Stairs | budcam | Flooring | 4 | 09-16-2009 12:12 AM |
| Am I SCREWED? Stairs & building code. | Armitage | Building & Construction | 24 | 06-26-2008 05:05 PM |
