Composite Door Surrounds - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-11-2015, 12:15 PM   #1
Rewards Points: 2
Unhappy
I need recommendations to replace existing wood Pilasters and Dentil Header, with Composite or similar product. I have tried to actually see two products (Fypon and Mid-America) only to be told only catalogs are available. I like AZEK, Veranda, etc. products and might be forced to piecemeal different shapes from different manufactures to make it look right and feel real. A Mid-America supplier did have a small sample. It LOOKS great from a distance, until you touch it. It has the feeling of plastic and hollow, not solid like wood or composite (AZEK). Some good features for Mid-America is that it does not need to be painted, in fact they do not recommend painting. Another is that it is not nailed or glued/cemented. It is secured by a J-Channel backing plate and a Base.
The Fypon (Foam product) must be painted.
So. Do I go the ala-carte route, or await further recommendations available in the Huntington,NY area?
handypfb is offline   Reply With Quote
Old 07-11-2015, 01:13 PM   #2
Rewards Points: 144
I would not go with composite.I would use pvc .Check out www.certainteed.com
mako1 is offline   Reply With Quote
Old 07-11-2015, 03:33 PM   #3
Rewards Points: 5,336
I would visit Kleet lumber or Burts Lumber on Park Ave, North of Pulaski Rd.
Ron
B. Franklin 1759
Hidden Fasteners for Composite Deck mattlreese Building & Construction 1 08-07-2014 09:20 AM
Replacing deck with composite decking, good or bad? rjohnson84 Building & Construction 2 07-25-2011 01:00 PM
Small composite deck-which brand to go with? stormchaser Carpentry 11 05-24-2011 10:49 AM
ptw Rim joist = composite fascia board max_wonder00 Building & Construction 3 10-15-2010 08:05 PM
Composite deck with wood railings? Or ditch the composite and go all wood? CoconutPete Building & Construction 5 07-29-2010 01:30 PM
