#1 |
column room divider
looking for ideas/examples.have approx.12' opening with 12" header between two rooms. thinking of 4' halfwall/bookcase coming in from each side with column between halfwall and header. doesn't have to be structural. also stairrail deadends into ceiling. any ideas? pics. would be great. I have added a picture to the album of what I'm talking about. thanks
Last edited by skeeter 152; 11-18-2008 at 06:21 PM. Reason: Added a note about a picture |
#2 |
column room divider
If I understand correctly, you're talking about a colonnade. See this example at a Chicago salvage place:
http://www.urbanremainschicago.com/i...px?itemID=1675 We had something like this at our previous home, a 1913's vintage American Foursquare between the living room and dining room. Ours didn't include bookcases. Instead, there were lower, boxed in areas with square columns above. We bought a salvaged colonnade with the thoughts of adding it to the family room we always planned to build. Instead we moved! So, I have the two bookcases from that set in my office and the columns are overhead in our barn. The craftsman style would be fairly simple to build, no turning or carvings. Try Googling for "colonnade room divider" -- that's how I found the example above. Tim |
#3 |
column room divider
thanks tim
#4 |
column room divider
You could also pretty easily frame out a knee wall and trim it out with oak if you are going for the craftsman look. Once side could be painted and textured drywall to match the room and the other side either bookcases or glass front cabinets.
Another idea would be to purchase some unfinished or finished upper kitchen cabinets which are 12" or so deep. You could mount them to the floor and put a wood top on them then run a spindle from the cabinet top to the ceiling. |
#5 |
column room divider
yes i have alot of ideas in my head.would like to see some pics.its for my sister in law
thanks
| Display Modes | |
| Raising Doorway Height (load bearing?) | treefrog | Building & Construction | 6 | 02-25-2008 10:11 PM |
| Heat pump in non insulated nor heated room | robdville | HVAC | 3 | 01-21-2008 03:51 PM |
| Hardwood flooring - 3 walls and a sunken living room | basledder | Flooring | 1 | 12-09-2007 06:34 PM |
| Room to Room Vent | cjpilot | HVAC | 5 | 12-02-2007 09:53 PM |
| Installing a structural fiberglass column | Weekend Warrior DIY | Building & Construction | 9 | 11-19-2007 01:33 PM |
