Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-18-2007, 11:47 PM   #1
Question collar ties explained?
i am building a summer cabin for my family...
It is a 900 sf floor with a 550 sf loft i ordered the plans online and have had no problems until now.
Roof plans call for 2 2x12 scabbed together for the ridge beam (30 ft span) and 2x10 for the rafters 16 oc.Plans call for 2x6 collar ties 48in oc, a min of 3 ft from the roof peak.
my confusion is the 48 oc does that mean 48in apart, ie only every forth rafter???????
can someone enlighten me
The cabin is 30ft by 30ft with exposed ceiling and no ceiling joists just collar ties and for some reason this doesnt seem like it will be enuf strength and support for a 6/12 roof maybe im wrong..
Thx in advance Troy
troycalm is offline   Reply With Quote
Old 03-19-2007, 12:06 AM   #2
Framing Contractor
Why don't you call the Architect who drew them. He would be the one to know.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-19-2007, 12:07 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thx in advance Troy
48" OC ... sounds about right, that is usually the minimum spread for collar ties; Collar ties do not support vertical loads. Their function is to keep rafters from spreading apart.
I posted this on a previous inquiry regarding collar ties:
"Collar ties are not installed for vertical loads, they are installed to re-inforce the rafters and roof structure from upward wind pressure and roof loads that can cause rafters to spread apart outward.
To illustrate: Take 2 playing cards, or 2 books, and lean them end to end to form an "A"....Where is the weight load? At the peak and at the bottoms. They support each other....there is no downward or vertical weight load under the areas of the 'A' form."
This Link has a good illustration on the end of the page:
http://tpub.com/content/engineering/.../14069_213.htm
- Build Well -
Old 03-19-2007, 12:21 AM   #4
Default Thx
thank you atlantawbconst that answered my question,that just doesnt seem like it would keep the walls from spreading.
as for Joe i have contacted the drafter and his reply has always been
2x6 collar ties 48in oc ,min 3 ft from peak he had never elaborated on 48 in
thx again
troy
Old 03-19-2007, 08:26 AM   #5
General Contractor
joasis's Avatar
Sounds interesting...from the framing description, that roof is going to weigh a lot. What pitch on the roof and how are the walls framed? Seems to me the architect is inviting a wall "sway out" problem.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulation Services
Oklahoma
405 314 5802
joasis is offline   Reply With Quote
Old 03-19-2007, 09:18 AM   #6
J. You know, your right. I was only looking at the title of the post and answering the collar tie question (Collar ties explained)
- It was late.
30' x 30' is a wide spread... I'd seriously think about getting the design checked-over and also consider web trusses instead of rafters ...
- Build Well -
Old 03-19-2007, 02:24 PM   #7
General Contractor
joasis's Avatar
At the very least, with the dimensions stated for the rafters.....it probably needs something like a fabricated timber frame truss, at least on the 10 and 20 foot mark. This must be way up north to need 2X10's for rafters every 16 inches...wow.
After re-reading this, I would say this needs a serious checck from another source......of course, there is no rule against over built.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulation Services
Oklahoma
405 314 5802
Old 03-20-2007, 02:10 AM   #8
Default ya
slope =6/12
run=15
overhang=1ft
heel= 6 7/8
seat= 3 1/2
common=1 1/2 x 9 1/4
ridge= 3'' x 11 1/4"
fascia= 3/4" x 9 1/4
ridge allowance= 1 1/2
adjusted run=14-10 1/2
this is being built in arkansas
Last edited by troycalm; 03-20-2007 at 02:12 AM. Reason: the wall framimg is standard 2x4
Old 03-21-2007, 11:48 PM   #9
troycalm was only concerned with the coller tie spacing I bet there are also wall ties on 48" oc. Maybe he'll get back and let us know.
Zero Punch is offline   Reply With Quote
Old 03-22-2007, 10:04 AM   #10
Default thx guys
Yes my concern was how to space the collar ties 48oc now i understand that but no there are no wall ties in the plans..
http://www.cabin-plans.com/store/mer...gory_Code=COZY
Old 03-30-2007, 09:15 AM   #11
The house that I build has a catheral ceiling its about 18 feet high and a span of about 26 some feet. When I put collar ties in I installed on every rafter ( funchion of collar ties has already be explained) then when I was ready to put in v-groove knoty pine I had plenty of nailers plus the added strenght (heavy snowloads). Roof in front of the house is 8/12 and the back is 11/12 with shingles so there was concern about pushing the walls that rafter were setting on, I installed a 6x8 hemlock beams this was build in an A, the horz. beams set on the plate and are fasten with two angle irons 4x4 these bolt thru the beam and thru the plate, where the beams meets in the middle I used diamond plate (diamonds towards the beam) this plate also holds the two beams that are at 45 degree angle from center up to the roof rafters, to bolt this together I used threaded rod when painted flat black the nuts on both ends look like bolt heads. to tie all this in I placed two beams on each end on top of the horz beams and ran them along the roof rafters and bolted a heavy collar tie to both sides. where the horz beams and these beams meet I again used diamond plate. I have a very nice beam thru the center of our big room and have tied opposing walls to keep them from spreading from heavy snow loads. You have been given some very good advise, one I believe was going to talk to a contractor, find one who builds post and beam they work with all the time and could give you the best way to do this. One last thing if you use v-groove knoty pine put in the house on sticks for several weeks that way when you install it will stay in place and not move around, high ceilings trap a lot of hot air install a paddle fan to push back down.
Gary
gary is offline   Reply With Quote
Old 03-30-2007, 11:55 AM   #12
Master Craftsman
Big Dave's Avatar
From looking at the plans on the link the loft area will keep the back wall from bowing out and the way the front rafters hang out over the front wall will help some. In a worse case scenario I would run two beams spaced evenly from the front wall to the loft area at the loft floor height to keep the front wall from bowing out. This will give a little bit of visual interest plus allow you a place to put some hidden lighting that can be focused on the ceiling above.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 04-04-2007, 12:04 PM   #13
mt232's Avatar
Default Big Dave
Took a look at your website....your work is incredible!
mt232 is offline   Reply With Quote
Old 04-04-2007, 04:16 PM   #14
Master Craftsman
Big Dave's Avatar
Thank you very much. I'm still trying to improve though.
More On This Topic
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
One of the enjoyable thing about gardening is being able to go out and pick and eat things that you have raised from the ground yourself. To preserve the seeds of this year's crop you must save the seeds. Some plants are more difficult than others to... Read More »
When it comes to a tornado it doesn't matter what the intensity of it is if your house is not properly built to withstand it. If your house is not wind-proofed it can suffer a lot of damage. Follow these steps to prepare for a tornado and prevent... Read More »
Learn tips on how to write 'roof beam' with the Chinese Radical of wood in this free video clip on Chinese characters and foreign languages. Read More »
raising collar ties ajoantmug Building & Construction 9 03-18-2007 07:15 PM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 06:16 PM
Removing Collar ties Mike2004 Building & Construction 6 12-16-2006 03:48 PM
Garden Ties "Mini Ties" Leenders Landscaping & Lawn Care 0 05-22-2006 12:37 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 01:19 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
