Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-17-2010, 08:27 PM   #16
Collar Tie for attic rafters
Thank you for the links. Just had the time to read through them. This is really helpful to my understanding. Especially the explanation of what collar ties really do.
I was not sure of the correct way to connect to two rafter ties together so I left them unconnected in the picture. The total span will be around 28' so two 14' long boards are needing to be connected. I'm researching what dimension (i.e. 2X4 or 2X6) the boards should be and how to properly connect them to each other and to the rafters. I'm also curious how much 'give' the board will have before tension kicks in and prevents any additional spreading and can hopefully find that answer with a few Google searches.
This forum is great. I wish I could sent you all a beer or two.
JoeT is offline   Reply With Quote
Doubling up rafters DbKam Building & Construction 2 10-24-2010 10:16 PM
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
Adding Collar Ties to make a ceiling Joe1. Building & Construction 18 09-11-2010 10:56 PM
Loose Collar Tie nofx1981 Building & Construction 6 02-09-2010 09:40 PM
Removing Collar ties Mike2004 Building & Construction 6 12-16-2006 02:48 PM
