Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-01-2010, 12:25 PM   #1
Cole Sewell Estate Series
The door sweep is torn on my storm door and I wondered how to replace it? There are two screws on a metal plate holding the old rubber on and it doesn't want to come off. Any hints?
JanisT is offline   Reply With Quote
Old 12-01-2010, 12:39 PM   #2
If it's just applied to the face of the door, use a sharp knife to score the paint line where the top of the metal strip touches the door. Then take a flat screwdriver/putty knife and tap it gently with a hammer to pop it off.
mrgins is offline   Reply With Quote
Old 12-02-2010, 08:30 PM   #3
You can buy replacement rubbers for the door. You can just unbend the crimped edge and pull out the damaged part. The new piece can be slid in. Just crimp the end after the install.
You do not need to remove the metal piece.
Ron
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Series or parallel runronno Electrical 29 07-17-2009 12:40 PM
Cole Sewell Screen Door LNova67 Carpentry 2 04-25-2009 09:14 PM
Series or Parallel Outlets Bocolo Electrical 8 02-06-2009 09:40 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 12:16 PM
