Coffered Ceiling Design.......... - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 03:46 PM   #1
Green Hat
Rewards Points: 170
Anyone have any experience with design software that will help me out with designing a coffered ceiling with faux beams?
I have tried multiple times to draw it out, however I am kind of stuck. There are a few areas that are small hallways and I have a bathroom to work around as well.
Basically, I am looking for something to input my dimensions in to, and it will do the rest.
Any suggestions would be awesome.
Thanks!
Mills314 is offline   Reply With Quote
Old 02-14-2012, 04:10 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
I, as well as a few others, are pretty fast with sketchup. Post up your dimensions or a scan of your hand-drawing and I'm sure someone could help you out.
hyunelan2 is offline   Reply With Quote
Old 02-14-2012, 04:17 PM   #3
Green Hat
Rewards Points: 170
Thanks man.
Just to give you the heads up, the plan is somewhat unorthodox.
I am building the coffered ceiling design with faux beams, then plan to use a backer and crown molding at a support for ceiling material, possibly 1/2" MDF due to it being more rigid than sheetrock.
Due to the high costs of relocating mechanical aspects of my basement, I need to have removable panels.
So in a nutshell, I am building a drop ceiling from scratch.
Old 02-15-2012, 04:19 PM   #4
Too Short? Cut it Again!
In other words, reinventing a more round wheel?
How faux and of what foam the beams? And they are to be attached to what and how if this is a drop ceiling? And, if I understand you, you plan to wrap crown molding around them? Again, real or how faux foam the crown? And then if I understand, with this faux foam grid hanging by angel wings as a drop ceiling, you want to float 1/2" MDF on the system edges of things?
Could work as many of the systems already engineered for this, to a point do, but why are you starting from scratch and not implementing one of them?
You cannot float 1/2" MDF on faux foam edges lad. It will come down on some poor soul's head!
http://www.fanaticfinish.com/pages/c...ing_system.cfm
I use Sweet Home 3D (free and open source) and not Sketch up but same difference. Send the dimensions and someone on this site will help you.
I won't if you continue to think you can float a ceiling weighing what you have in mind without some sort of grid system to hold the pieces. You cannot do it with faux everything.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
What to do with this old ceiling? mudworm Building & Construction 4 07-17-2011 05:54 PM
Coffered Ceiling yaleusc Carpentry 2 07-13-2011 04:06 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
