Closing Up Interior Doorway - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 09:31 PM   #1
Closing up interior doorway
Hello everybody.
I'm looking to remove an interior door(that's not required by code) and seal it over with drywall. Just a quick question about the framing.....
1)Do I need to remove anything other than the moulding and the casing?
2)Do I need to add a bottom plate?
3)Can I leave the jack studs and king stud in place and just add a 2x4 in between?
4)Best to use nails or screws?
This forum is so helpful. Thanks to anyone in advance for your input!
Dr.Fugazi is offline   Reply With Quote
Old 03-30-2011, 09:49 PM   #2
Old School
Willie T's Avatar
Originally Posted by Dr.Fugazi View Post
Hello everybody.
1) No
2) Yes
3) Yes
4) Screws
Willie T
Old 03-30-2011, 09:53 PM   #3
Rewards Points: 5,336
Hello everybody.
You remove the entire door frame and the molding.
You install a bottom plate.
You can use nails(10D) or screws(2 1/2-3" )
Keep the framing in place that's there.
Add enough 2x4's to keep the spacing about 14 1/2" between studs.
Ron
Old 04-01-2011, 06:25 PM   #4
Ron
Seconded, although, as a remodeler, I often use screws to avoid shaking surrounding areas with hammer vibrations
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
Willie T (04-02-2011)
Old 04-01-2011, 11:27 PM   #5
Too Old
Remove the door, casing, and jamb.
Insall the bottom plate
Add stud to each jack stud, Add studs for spacing in between
Make sure framing is flush to existing then drywall
havalife is offline   Reply With Quote
Old 04-06-2011, 10:46 PM   #6
Kudos
Thanks to everyone for their advice. Went well.......despite one minor hiccup.
I take everything off and realize that I have 5" studs. Luckily the guy at Home Depot was cool and ripped down 2x6s(although I think he wasn't supposed to) for me as I really wasn't too comfortable doing it myself.
Thanks again!
Self closing hinge removal azhomeowner Remodeling 5 08-07-2012 01:59 AM
Garage door problem - not closing completely francis Electrical 4 07-08-2010 12:27 AM
installed new bedrm door-hinges bind, 2" from closing ecowarrior Building & Construction 0 05-10-2010 10:00 AM
closing vents in unused living space scottydel HVAC 1 12-05-2006 01:39 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
