Closet Pole Install ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 09:11 AM   #1
Closet pole install ?
Here is my my problem I currently have a closet with wire shelves that keep falling down due to being installed in drywall there are no wooden studs only metal studs . What would be the solution to fix this without ripping the drywall down and installing wooden studs for support I am open to suggestions on different products other than the wire shelves for hanging clothes . Thank you
ants1929 is offline   Reply With Quote
Old 07-25-2011, 09:42 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
There are different wire shelf systems, some better than others. You may want to do a search and see which ones will work for you. There are different type of fasteners for metal studs also that you can find online that will hold good.
If all else fails you can go back to wooden shelving or look into some of the closet systems.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-25-2011, 10:05 AM   #3
Old School
cabinetman's Avatar
Sheet metal screws should hold in metal studs if driven properly. I use a cordless on slow speed, and when the screws are close to tight, just bump the trigger to tighten. That prevents over spinning.
You could surface mount a horizontal wood board on top of the drywall, to screw your existing shelving to. As Jim suggested check out different systems.
cabinetman is offline   Reply With Quote
Old 07-25-2011, 01:43 PM   #4
Rewards Points: 5,336
The stud material shouldn't be an issue as the screws that hold the brackets can be installed with plastic anchors, directly in the sheetrock.
If these have been compromised, they were either installed incorrectly or the weight put on the shelves were too much.
Ron
B. Franklin 1759
Laundry closet decision LClark Remodeling 2 06-26-2011 06:19 AM
Sliding mirror closet doors Liv Remodeling 1 02-17-2011 12:07 PM
240V/30A outlet install with 1/2" 2 pole breaker neal0713 Electrical 5 02-03-2011 10:35 AM
Need Help Troubleshooting 3-way + Single Pole Switch Install OmegaRed1723 Electrical 6 10-09-2009 10:25 PM
Yet another distance from Pole and meter to house question urbanfarmer Electrical 9 05-25-2008 06:38 PM
