Closet Organizer Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 08:17 AM   #1
Rewards Points: 189
I am in the planning stages of what will become a closet organizer for a large walk in closet. In one area of the closet I am looking to install an 8 foot long 20 inch deep shelf. Under the shelf, but not attached to it, I will run a rod for hangers. I think that I will use for the shelf a 3/4 inch 20x96 stain grade ponderosa pine panel from lowes. See the product here: http://www.lowes.com/pd_72884-99999-...boards$y=0$x=0
A friend of mine says that I should not use this product because it lacks stiffness and will sag too easily. He recommends using a sanding plywood. What do you think? I was planning to brace the shelf on three of the four sides using 1x3 pine. I was also planning to attach the shelf to the bracing with glue and screws. Should I also brace the pine on the front side of the shelf? Should I avoid the lowes panel and use plywood? In what other ways should I brace the shelf? I was thinking of two triangular wood braces creating three separate equidistant sections or, maybe full pine boards 20 inches deep running the full length to the floor - through which the rod could run. I'd appreciate any feedback you could provide.
Thank you for considering my questions.
aumanpj is offline   Reply With Quote
Old 07-23-2010, 10:19 AM   #2
Rewards Points: 5,336
Any product you use to span 96" will need intermediate support under it. For 96" I would have 2 end supports and 2 intermediate supports.
Ron
Old 07-23-2010, 11:37 AM   #3
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
How to cut a countertop to fit exactly within a closet? docprego Carpentry 4 06-05-2008 10:22 PM
Closet organizer helpless handyman Carpentry 4 11-09-2007 11:58 AM
