Closet Opening - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 01:55 AM   #1
Closet Opening
I have two problems with my closet door opening.
openign is 22" which is not standard size. Is there any way around it, or I will have to order custom made doors.
One wall is not straight, it appears that opening on top ois 3/4 inch wider than on bottom. Is there a fix for it, or i will have to take wall down.
Thank you
remodel-virgin is offline   Reply With Quote
Old 06-13-2009, 06:06 AM   #2
Flat slab hollow core doors can be cut to size fairly easily, considerably cheaper than custom doors. If you want raised panel doors, that gets more difficult, although you probably can cut 1" off each side. Might be easier to redo the closet opening, which would allow you to correct the wall misalignment???
Old 06-13-2009, 08:29 AM   #3
Rewards Points: 5,336
Use the opening you have as a rough opening and install a smaller pre hung unit.
Ron
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Opening for attic stairs sk8z Remodeling 16 03-17-2008 12:52 PM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
