Closet Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 06:06 PM   #1
closet door
door is sticking when I try to close the doors
liz4649 is offline   Reply With Quote
Old 03-25-2012, 07:55 PM   #2
Rewards Points: 1,668
top, bottom, etc..more info needed.
Do you speak as you write? I doubt it. Try to write as you speak; it'll be more helpful.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
woodworkbykirk (03-25-2012)
Old 03-25-2012, 08:13 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
what type of doors. is it a single, double. bifolds... it can be any number of things.. the hinges are loose. excess paint build up .. the frame may have shifted causing it to bind
woodworkbykirk is offline   Reply With Quote
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Security screen door dangerp Carpentry 4 09-22-2010 07:02 PM
Laminate Floor into closet under door jam jromjam Flooring 1 07-10-2009 06:59 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
