Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-12-2011, 12:20 PM   #1
Weekend Builder
Crackers's Avatar
Closet in bathroom???
Hi, just bought a house that needs some help. One of the things is that the bathroom (which has no door, only an archway????) has a closet inside.
Is there a problem with this? Will the clothes get destroyed from the humidity?
Here is a drawing of the current layout, and the original which can be found in several other similar houses.
Your thoughts?
ps. what is with no door on a bathroom
Crackers is offline   Reply With Quote
Old 10-12-2011, 01:29 PM   #2
Tileguy
Bud Cline's Avatar
Things to consider are frequency and duration of shower use, and whether or not there is proper exhaust in place to evacuate the moisture from the room.
There is no way to know what you are up against without some experimentation over time.
Old 10-12-2011, 03:08 PM   #3
Tizzer's Avatar
You can frame in the toilet like in the similar diagram if you want privacy. Is there a fan in the bathroom?
I have a vanity cabinet under my sink where I keep towels & such with no problems. I probably wouldn't use that cabinet for my good Sunday duds, but you could use it for coats or something.
Tizzer is offline   Reply With Quote
Old 10-12-2011, 04:38 PM   #4
As for no door, not that uncommon, particularly if it is a master bedroom with a master bath, but not that hard to install if you want one. In regard to the closet, perhaps you could relocate the door, to make it accessible from another room?
Old 10-12-2011, 05:05 PM   #5
I see no issue with a bath closet. The bath should have an effective fan, so humidity should not be of concern.
Ron
B. Franklin 1759
Old 10-12-2011, 05:19 PM   #6
Nothing I like better than a nice hot shower and then grab a big hooded parka and put it on!
So this would be handy.
oldhouseguy is offline   Reply With Quote
Old 10-12-2011, 08:37 PM   #7
A bathroom without a door would be handy if you ever have poutine with bad gravy!
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 03:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 07:19 AM
Closet vs bathroom extension Stephen S. Remodeling 11 03-20-2010 11:01 PM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
new bathroom water closet TonyD Plumbing 1 03-11-2008 11:27 PM
