Click Lock Flooring Router Bit - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-27-2009, 06:21 PM   #1
click lock flooring router bit
I want to make my own click lock wood floor out of planks. Does any know of a router bit set that I can use to make the click lock joints?
davimarti is offline   Reply With Quote
Old 09-29-2009, 12:54 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
To my knowledge, there aren't commercially available bits for retail purchase. I think you'd have to get a cutter(s) custom made. And if you are interested in trying to make your own snap together flooring planks, I think you'd have to use composite material of some sort. I don't think you can use solid wood for snap lock joints. The tongue of the joints is very thin, and real wood would likely break a lot along the tongue, as the grain runs parallel to the tongue. That is why all snap lock flooring is either composite material, or plywood type products. But if you do make your own out of composite or ply, you have to worry about how to finish the tops to make them look like legitimate flooring. Are you just trying to repair already manufactured snap lock flooring?
adpanko is offline   Reply With Quote
Old 09-29-2009, 03:14 PM   #3
Plank flooring
You may have to go with tonge and groove router bits depending on the thickness of your planks.
Texas SawDuster is offline   Reply With Quote
Old 09-29-2009, 08:58 PM   #4
Thanks, yes I am making it out of ply wood for our summer place,,,did not want to have to cut it on my table saw..hoping to find router bits for it
Swift Lock laminate wood flooring on steps? Leche4evr Flooring 1 08-29-2009 01:49 PM
Bruce lock and fold flooring vs pergo 2goresmom Flooring 2 06-15-2009 08:51 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-31-2008 12:03 AM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 03:16 PM
