Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-31-2012, 09:26 AM   #1
Clapboard Questions
I live in New England and will be painting my house soon, but first need to replace rotted and split clapboard; I'll use pre-primed red cedar.
I'll need ~850 linear feet which will cost $500+ dependent on where I buy it. I know there are different grades of clapboard so a few questions on where to buy it.
- Home Depot or Lowes charge $0.625 a linear foot. Local lumber yards charge ~$0.79 a linear foot. From a quality perspective, is there any reason to pay more at a local lumber yard? For example, will the Home Depot or Lowes one tend to curl up along its length or not last as long for some reason?
- I might need to mix bundles from a few places to get the quantity I need. Is there any issue with doing this?
- For boards that will be cut, what primer is best for the now unprimed cut end? The house will be stained, so I do not want to use caulking on the ends.
jdjd is offline   Reply With Quote
Old 07-31-2012, 09:33 AM   #2
Clapboard Questions
If you just going to paint it you would not use any primer, just prestain the cut ends with two coats of the same stain your going to be using.
Where is it rotting? Is it at the bottom of the wall?
Post a picture, there may be some way to prevent it from happening again.
Old 07-31-2012, 06:59 PM   #3
Retired Cabinetmaker
woody4249's Avatar
Clapboard Questions
Quote
" I might need to mix bundles from a few places to get the quantity I need.
Is there any issue with doing this?"
ooooooooo...me thinks you need to check apples for apples. Every time I've come up short and bought from two or more different sources, I've had issues not only with quality but with profile match.
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 03:37 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 01:59 PM
Paintbrush or sprayer for clapboard house exterior dvarga Painting 7 01-04-2009 02:12 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Painting Clapboard BilHam Painting 4 06-07-2007 11:06 PM
