Clamping Board W/ Sawhorse - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 03:48 PM   #1
Clamping Board w/ sawhorse
Hi,
I am using powertool version of shears to cut 1/2 hardi-backerboard. I need to clamp the backerboard to sawhorses or similar to get a good cut. Any tips? or any special clamps?
My sawhorses are those plastic ones that fold; like these. The sawhorses bend when I clamp to them.
Thanks in advance!
Red
RedBear is offline   Reply With Quote
Old 04-07-2011, 04:41 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Screw a sheet of plywood to the sawhorses, then clamp the Hardi to the plywood.
tcleve4911 is offline   Reply With Quote
The Following 2 Users Say Thank You to tcleve4911 For This Useful Post:
mem (04-08-2011), RedBear (05-03-2011)
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
