Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-18-2012, 02:19 PM   #1
Changing wood spindles to wrought iron.
I'm guessing the wrought iron spindles are at least half the dia as the wood where it mounts to rail and base. I've never done this but would like to help my friend update his handrails.
My main question is; plug holes, sand, and refinishor trash the handrail and baseplate and start over?? What would you do??
Squeakyhinge is offline   Reply With Quote
Old 12-18-2012, 06:28 PM   #2
chitownken's Avatar
Time versus money. Would be faster to replace the base and rail, but that costs money. If the base and rail are painted, then plugging and refinishing is an option. If they are stained, it would be really hard to hide the plugs.
chitownken is offline   Reply With Quote
Old 12-18-2012, 06:40 PM   #3
also be aware that if the metal spindles are thinner that the spacing between the spindles may not meet code esp if the ones there now are at maximum allowed distance apart - 4 inches or less between the spindles at the widest spot.
Old 12-19-2012, 03:45 PM   #4
Sorry I didn't respond. My email notification never seems to work or I miss it or something. Thank you for the responses.
Re. plugging the holes. I forgot to mention that many holes are at an angle. Would that make it much harder to plug. Another use for the multi tool. Would you buy oak dowel and taper with belt sander, cut, taper...? I'm conservative so I would probably opt for plugging the holes. However, I imagine on the base plate the opposing grain from the plugs would stand out significantly. Would probably have to make a sample to see results. I this why you say if they are stained it would be more difficult instead if they were painted?
What is the spacing? 4" on centers?
Old 12-26-2012, 02:19 PM   #5
Maybe the "base" piece at the bottom of the spindle will help hide the old hole? However, the chances of all the spindles landing in the same spot is probably slim, especially if the spacing changes.
Question: with wood spindles narrow at the top and wider at the bottom, where does the code spacing apply? Top or bottom?
Old 12-26-2012, 06:22 PM   #6
chitownken's Avatar
As far as matching the grain, you can buy plugs in various species of wood that have cross grain (runs horizontally) instead of end grain. Or you can get a plug cutter of the right diameter and make your own. Might not matter on the bottom side of the hand rail if it is not visible. The code here is 4" between balusters at the widest point. 4" on center would be closer than the code requires, which is fine.
The Following User Says Thank You to chitownken For This Useful Post:
Squeakyhinge (12-26-2012)
Old 12-31-2012, 12:10 PM   #7
Bump since I'm off work ha ha.
Old 01-16-2013, 10:55 PM   #8
Anyone familiar with the transformer system for easily replacing balusters with wrought iron?
Old 01-17-2013, 07:31 AM   #9
Super Moderator
Post a link----I suggest you start fresh---unless the handrails and base plate are something very special the work of trying to plug all of the old holes and make the tired old wood look good is wasted energy--
oh'mike is online now   Reply With Quote
Old 01-17-2013, 08:58 AM   #10
I have no idea what the transformer system is but I got an idea while on the throne. That's usually where my better ideas originate.
If you will leave the wood and install a wrought between each, that will be nearly 2 X better than code and will satisfy any decor trends that may change at least 5 times in 10 years.
Fairview is offline   Reply With Quote
Old 01-18-2013, 03:33 PM   #11
Yes very true.
They (http://thetransformersystem.com/) advertise that all the balusters can be changed in one day. Has anyone discovered any mechanical bugs in this system?
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
wrought iron security door frame diy888 Windows and Doors 0 01-16-2012 10:08 AM
restain wood changing color jimmy262317 Woodworking 0 11-09-2011 08:16 PM
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
Wrought Iron Railings for Stairs ThomF Carpentry 3 11-01-2006 08:04 PM
