Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-03-2008, 10:41 PM   #1
Default Changing Alligator Barn into house
YeP, that's right. I need some advice on the roof trusses. I have a 30 wide by 35 long bldg.
I would like to go with an open ceiling/truss system. Kinda going for the cottage look.
I was wondering if I could go with open trusses on half of it and the other half be attic trusses , so I could have a loft? And what price difference there would be compared to just regular 30' trusses? Any takers?
Rosie is offline   Reply With Quote
Old 01-04-2008, 11:34 AM   #2
Master General ReEngineer
Ayuh,.......
You'll probably need the in-put from an Engineer to determine whether the Walls will support what you're looking to Do.......
Maybe you could tell us More about how well built this Gator Barn is built.......
Old 01-04-2008, 01:30 PM   #3
Woodworker and Contractor
Kingfisher's Avatar
Have you talked to the build department in your area, FL I assume? Lots of code issuses going from a barn to a home. The cost for the more open and loft truss is not that much, maybe $1000 more, and easly worth it for the added living space.
Kingfisher is offline   Reply With Quote
Old 01-04-2008, 10:31 PM   #4
Thanks for the advice. I'm in Louisiana. This Alligator barn was turned into a pole barn about 10 years ago. So it's pretty much a 30 x 35 pole barn. The only problem is the floor. It is cement that slopes down from the middle about 8 inches on both sides to drains. I'm going to have to put in some sleepers to make the floor even , or cement the rest of it in to make it even. Anyone know which would be cheaper? Also I had a contractor come out and he said the 2x4 walls that are up right now are ok to use. The roof will have to come off and trusses put up. Also a problem might be the plumbing. It does have drains with pvc about 5 inches in diameter, is there anything I could use those for? Just curious. We'll probly have to crack the cement to get in some plumbing. Thanks guys, this is going to be a very interesting project since I am going to try to stay under 30 grand .
Old 01-05-2008, 10:48 AM   #5
Kingfisher's Avatar
really surprised that you can do that. After Hugo rolled throught my small home town the Fema rules became The Words of God. It was impossiable to do anything. How close to the coast wind zone wise and what Flood are you in. Both of these will affect how you have to upgrade the roof to might the code. Sleepers are cheaper but the concrete is a faster solid fix and you can run some rebar through the poles as a secondary foundation because I doubt they did the fist time. Still really don't see how they are letting you do this?
Old 01-06-2008, 01:26 AM   #6
We live in northern Lousiana so no problem with wind etc. As far as the building codes, I called and they said that since it is a preexisting bldg. I don't need a permit. It is real lax here on permits etc.... I actually know a man who built a new house with no bldg permit what so ever. It doesnt look that good but he did it. Shocked me that he could do that. I never even thought about the rebar in the slab. I actually know the guy who built it, I might give him a call and ask if they put any in it.
Old 01-06-2008, 05:26 PM   #7
Is this with or without the alligators still in there??
How are you planning to keep all the rodents and insects out of this 'structure'??
IF the roof AND floor isnt going to stay,,,what are you gaining from this vs NEW construction?? I obviously DONT understand!!
Is their ANY mold or bacteria that needs removed with aminals formerly in there??
justdon is offline   Reply With Quote
More On This Topic
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
Nothing bespeaks country style like alligator skin boots. The shiny, quality hide puts a lacquer of high fashion on a cowboy tradition. While alligator skin boots don't come cheap, the years of shiny good looks you'll get out of them will make the price... Read More »
The law didn't permit buying or making real alligator skin boots until a short time ago. Alligator was on the endangered species list for about 20 years, but is no longer. Conservationists are letting manufacturers use the skins to keep the population in... Read More »
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 07:54 PM
Changing filter in Whirlpool whole house water filter farnamct Plumbing 6 09-13-2009 11:31 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 07:42 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 13 08-03-2007 09:48 PM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing 3 03-27-2007 02:16 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
