Chalk Line For Installing Base Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-23-2013, 12:33 PM   #1
Rewards Points: 1,062
Chalk line for installing base cabinets
People,
When snapping a chalk line as a guide to install base cabinets, do you start at the top of a cabinet, measure the height, mark, and then use a level to align a chalk line?
Then, what if you have a "bump" in the floor/slab which could elevate an adjacent cabinet? Cant shim that one, right? How do they do it?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 02-23-2013, 01:54 PM   #2
Rewards Points: 512
i start with my base corner cabinet.
get it perfectly level and screwed in place
then i run a level line off of that in either direct.
i pencil it not snap it.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
noquacks (02-24-2013)
Old 02-23-2013, 02:08 PM   #3
Rewards Points: 636
i use a laser now but i used to use a level check floor to find the highest point if floor is not level and then draw a line at that height on wall
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following 3 Users Say Thank You to jaydevries For This Useful Post:
joecaption (02-23-2013), noquacks (02-24-2013), oh'mike (02-23-2013)
Old 02-23-2013, 06:03 PM   #4
Rewards Points: 14,006
You have to find the highest point first as suggested.
Cabinets almost always have to be shimmed to make up for the lower areas.
If you just started in the corner as suggest and the floor sloped up from there then there's no way to make up for it.
Since I bought my self leveling lazer lever it's made a ton of jobs so much easer.
Once you do find that high spot and marked it you can use the longest level you have to mark the wall.
Then you can start installing from an inside corner.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Old 02-23-2013, 06:53 PM   #5
Framing Contractor
Rewards Points: 120
Why not just continue using the laser to mark the wall instead of the level?
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
Old 02-23-2013, 07:10 PM   #6
Davejss's Avatar
Rewards Points: 776
I find that lasers are ok for rough lay outs, but the beams are too large for accurate finish work.
I use my six foot level on the floor, find the highest spot, mark the wall and snap from there. I use a small diameter finish line. I think Lenox makes it. It's a bit thinner than standard lines. I also use a drafter's mechanical pencil for drawing thin lines. For super thin and accurate marks I use a knife.
Davejss is offline   Reply With Quote
Old 02-23-2013, 07:17 PM   #7
I do, what's the chance a DIY is going to have a $700.00 lazer level laying around.
oh'mike (02-23-2013), woodworkbykirk (03-01-2013)
Old 02-23-2013, 07:36 PM   #8
DIY staff
Rewards Points: 7,174
Just a note----if the 'hump' is small----some times modifying the cabinet by cutting off some of the bottom is in order---just a thought----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
noquacks (02-24-2013), princelake (02-24-2013)
Old 02-23-2013, 08:11 PM   #9
where you getting your lazers at joe? i got one at HD on clearance for 29.00 a few years ago and it works great.
Old 02-23-2013, 10:31 PM   #10
Rewards Points: 790
Starting from the highest point is the norm, but make sure you have 34 1/2" from the finished floor to the bottom of the counter top nosing at the spaces where the under counter appliances will go.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Old 02-23-2013, 10:50 PM   #11
http://www.engineersupply.com/Johnso...t-40-6522.aspx
I need to be able to level long fences, decks, figure out where to start siding on old house that have been added onto and are sagging so the last outside corner comes out even so a $30.00 levels not going to cut it.
Old 02-24-2013, 09:00 AM   #12
Wow, many thanks to all here who contributed!! I learned a bunch! Now, the job wont have any surprises (I hope).
Old 02-24-2013, 09:01 AM   #13
Thaks, but not clear on what you mean by " nosing at the spaces........".
under counter appliances? Why does this matter much?
Old 02-24-2013, 09:08 AM   #14
Set to low and there not going to fit.
Old 03-01-2013, 03:11 PM   #15
Getting ready to start- one thing- when hanging upper cabinets (not base cabinets), does one have to hope/depend that there will just happen to be a stud in wall at the right place to screw in screws? Or, do you beforehand, determine where ALL studs are, (typically, every 16"), mark, then you have a better idea where to screw each hanging cabinet?
Also, how many per box? 2 on top . left/right, and 2 low, left right?
Thanks!!
Raising base cabinets ljcilli Kitchen & Bath Remodeling 1 01-09-2013 04:28 PM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 02:29 PM
Type and grade of plywood under kitchen base cabinets? vsheetz Carpentry 5 11-24-2008 04:14 PM
Making a straight chalk line Krichton Building & Construction 11 03-19-2007 07:30 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
