-   -   Chalk line for installing base cabinets (http://www.diychatroom.com/f14/chalk-line-installing-base-cabinets-172721/)
noquacks 02-23-2013 12:33 PM
People,
When snapping a chalk line as a guide to install base cabinets, do you start at the top of a cabinet, measure the height, mark, and then use a level to align a chalk line?
Then, what if you have a "bump" in the floor/slab which could elevate an adjacent cabinet? Cant shim that one, right? How do they do it?
princelake 02-23-2013 01:54 PM
i start with my base corner cabinet.
get it perfectly level and screwed in place
then i run a level line off of that in either direct.
i pencil it not snap it.
jaydevries 02-23-2013 02:08 PM
i use a laser now but i used to use a level check floor to find the highest point if floor is not level and then draw a line at that height on wall
joecaption 02-23-2013 06:03 PM
You have to find the highest point first as suggested.
Cabinets almost always have to be shimmed to make up for the lower areas.
If you just started in the corner as suggest and the floor sloped up from there then there's no way to make up for it.
Since I bought my self leveling lazer lever it's made a ton of jobs so much easer.
Once you do find that high spot and marked it you can use the longest level you have to mark the wall.
Then you can start installing from an inside corner.
sixeightten 02-23-2013 06:53 PM
Why not just continue using the laser to mark the wall instead of the level?
Davejss 02-23-2013 07:10 PM
I find that lasers are ok for rough lay outs, but the beams are too large for accurate finish work.
I use my six foot level on the floor, find the highest spot, mark the wall and snap from there. I use a small diameter finish line. I think Lenox makes it. It's a bit thinner than standard lines. I also use a drafter's mechanical pencil for drawing thin lines. For super thin and accurate marks I use a knife.
joecaption 02-23-2013 07:17 PM
I do, what's the chance a DIY is going to have a $700.00 lazer level laying around.
oh'mike 02-23-2013 07:36 PM
Just a note----if the 'hump' is small----some times modifying the cabinet by cutting off some of the bottom is in order---just a thought----
DannyT 02-23-2013 08:11 PM
where you getting your lazers at joe? i got one at HD on clearance for 29.00 a few years ago and it works great.
carpdad 02-23-2013 10:31 PM
Starting from the highest point is the norm, but make sure you have 34 1/2" from the finished floor to the bottom of the counter top nosing at the spaces where the under counter appliances will go.
joecaption 02-23-2013 10:50 PM
http://www.engineersupply.com/Johnso...t-40-6522.aspx
I need to be able to level long fences, decks, figure out where to start siding on old house that have been added onto and are sagging so the last outside corner comes out even so a $30.00 levels not going to cut it.
noquacks 02-24-2013 09:00 AM
Wow, many thanks to all here who contributed!! I learned a bunch! Now, the job wont have any surprises (I hope).
noquacks 02-24-2013 09:01 AM
Thaks, but not clear on what you mean by " nosing at the spaces........".
under counter appliances? Why does this matter much?
joecaption 02-24-2013 09:08 AM
Set to low and there not going to fit.
noquacks 03-01-2013 03:11 PM
Getting ready to start- one thing- when hanging upper cabinets (not base cabinets), does one have to hope/depend that there will just happen to be a stud in wall at the right place to screw in screws? Or, do you beforehand, determine where ALL studs are, (typically, every 16"), mark, then you have a better idea where to screw each hanging cabinet?
Also, how many per box? 2 on top . left/right, and 2 low, left right?
Thanks!!
