Chair Rail Woithout Door Moulding - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 02:47 PM   #1
The Big Builder
Chair rail woithout door moulding
Hello everyone,
I was asked to help a friend install a chair rail in their dining room because I have done it before. Unfortunately I have only done it where the doors to the room also had door frames. This dining roo. just has the sheetrock corners.
I am lookinf doe visually appealing options for how to end the chair rail in the room. I have seen people cut a very small piece to cap the end but I don't know how that would look when there are two different colors on the wall.
What are your suggestions?
Stephen
bigbavarian is offline   Reply With Quote
Old 05-06-2011, 02:56 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
I think you have 2 options.
1. Cut returns on the end of the chair rail.
2. Miter an edge onto the end.
(images found on Google)
hyunelan2 is offline   Reply With Quote
Old 05-06-2011, 04:31 PM   #3
Old School
Willie T's Avatar
Dang, hyunelan2, might be about time to sharpen that blade.
Willie T
Old 05-06-2011, 04:41 PM   #4
hyunelan2's Avatar
Rewards Points: 686
Not my pictures
I agree though.
Old 05-06-2011, 06:19 PM   #5
KemoSabe
loneframer's Avatar
Returning the end into the wall is the best option IMO. As for multiple paint colors, straight-edge the Chair rail color out to the corner and call it good.
This project will have all white from the rail down, but it's the same principle, carry the chair rail color to the corner.
Chair rail woithout door moulding-009.jpg   Chair rail woithout door moulding-005.jpg
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 05-09-2011, 07:59 AM   #6
The Big Builder
Thanks everyone for the suggestions.
Old 05-09-2011, 10:58 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 180
If they wanted a heavier looking rail you could run one run right side up and another run upside down jammed tight under the top run. At the ends, 45 the top run back then the bottom run back to form a V, then cut a piece of the rail to fit. It will look like the rail runs across the room, goes down to the other run and back. Man I know I am not explaining this right.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Installing chair rail over uneven sheetrock krazykarr Drywall & Plaster 10 12-20-2011 12:51 AM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
Painting/staining crown moulding and chair rail Gypsy601 Interior Decorating 8 07-05-2011 04:51 PM
Choice: nicer chair rail w/splice vs no splice bergerdude Carpentry 9 07-07-2010 09:57 AM
Removed Chair Rail - Need to Patch Who Dey Painting 7 03-04-2010 02:43 PM
