Chair Rail & Wall Moldings - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 08:21 PM   #1
What is the standard height, if there is such a thing, for installing chair rail? I would also like to know what type (name) of the best molding to use to design the decorative wall frame moldings. The types you see in the expensive homes that usually form large and small retangular frames.
joe3534 is offline   Reply With Quote
Old 12-01-2008, 10:53 PM   #2
To determine the height of your chair rail, measure the height of the ceiling and divide it by three. The general rule is that the chair rail should be about 1/3 of the way up from the floor (between 32" and 36" for an 8' ceiling). You can also slide a chair up to the wall and mark where it will hit on the wall.
As far as wainscot type molding, visit your local lumber store and look at their selections. You can use a regular panel molding, you can use chair rail there, too, or I've used shelf edge molding a few times. As long as it lays flat on the wall, you can pretty much use anything you like.
Jeeper1970 is offline   Reply With Quote
Old 12-04-2008, 06:43 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
I agree with Jeeper, this is what I was told many years ago as far as the height of the chair rail. As far as the wall molding, most of the times the 1-5/8" base cap is what the designers have picked. but it all depends on your taste. BOB.
Old 12-04-2008, 05:41 PM   #4
Drywall contractor
Rewards Points: 1,070
Just one other thought on chair height.... if you're using a wianscot below, you get three 32" pieces out of an 8' sheet of panel goods. If you go 36", you waste 2' of material. I think the "decorative wall frames" you're asking about is what are called "shadow boxes" in this area. May have other names in other areas. Picture mold is commonly used to "frame" them.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
decorative trim and chair rail. What are the rules to make it look good? Bacardi 151 Carpentry 10 10-18-2007 02:37 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Wall lamps and chair rail alvanos Carpentry 1 04-26-2006 12:35 PM
