Chair Rail - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 06:33 PM   #1
ajp
chair rail
what is the compound angle for a chair rail that turns an outside corner on a level line, then begins a 30 degree angle upward on a stairwell
ajp is offline   Reply With Quote
Old 02-27-2012, 07:12 PM   #2
Rewards Points: 1,520
I'lll guess 45*, 15*
bob22 is offline   Reply With Quote
Old 02-27-2012, 07:34 PM   #3
Rewards Points: 12,794
Every stair case is going to be differant so it's not likly someone's going to come up with the right angle.
I would do some measurements from the floor up to the bottom of the chair rail on the wall, then mark the same measurement from the the outside edge of the treads to the same height on the wall. Snap a blue chaulk line and use one of these to figure the angle.
http://images.search.yahoo.com/image...mb=cpCLpHoH11V
Old 02-27-2012, 07:55 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Hold up the 2 pieces, or 2 scraps, and scribe them together.
titanoman is offline   Reply With Quote
Old 02-27-2012, 07:57 PM   #5
It's going to be a compound angle so it's tricky to just scrbe it.
Old 02-27-2012, 08:13 PM   #6
Old School
Willie T's Avatar
You're going to try to make a 30 degree rake match a flat (horizontal) run around an outside corner? I suspect you'll have to turn that corner flat first... then use a slim "transition" wedge.
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
BigJim (02-28-2012), kj6887 (03-01-2012)
Old 02-27-2012, 08:54 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
if you have some scrap lumber or mdf rip some 2" strips to use as test peices.. use this to find the angles of the cut then duplicate it on the actual chair rail. just another simple trim carpenter trick for finding difficult angles
woodworkbykirk is offline   Reply With Quote
Old 02-27-2012, 11:38 PM   #8
Rewards Points: 83
That's not a trick! That's cheating!
rubberhead is offline   Reply With Quote
Old 02-27-2012, 11:45 PM   #9
I've never once seen that return and then the angle as shown in the picture.
Far better better to have one double bevel cut.
Old 02-28-2012, 01:12 AM   #10
recently retired
Rewards Points: 280
Here's an article which may show why Willie is right. http://www.thisiscarpentry.com/2010/...board-returns/
Keith Mathewson is offline   Reply With Quote
The Following 3 Users Say Thank You to Keith Mathewson For This Useful Post:
kj6887 (03-01-2012), oh'mike (02-28-2012), Willie T (02-28-2012)
Old 02-28-2012, 08:15 AM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Dead on.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 4 Users Say Thank You to BigJim For This Useful Post:
Keith Mathewson (02-28-2012), kj6887 (03-01-2012), oh'mike (02-28-2012), Willie T (02-28-2012)
Old 02-28-2012, 10:51 AM   #12
Old School
Willie T's Avatar
I will admit that I HAVE, upon occasion, split the flat piece back for a foot or two, then wedged the profile wider to match the raked side..... then filled the split with spackling, and sanded it to match the raked profile.
A PITA, and not real professional, but I got away with it in instances where the Homeowner just didn't understand joinery, and insisted that the two should be able to match up.
Of course this will only work with paint grade.
Willie T
Old 02-28-2012, 04:55 PM   #13
Disabled wood vet
titanoman's Avatar
Is "joinery" really a word?
What about "jointery"?
Old 02-28-2012, 06:03 PM   #14
Not so new
12penny's Avatar
Rewards Points: 520
Joinery is the correct spelling.
12penny is offline   Reply With Quote
The Following 3 Users Say Thank You to 12penny For This Useful Post:
kj6887 (03-01-2012), Willie T (02-28-2012), woodworkbykirk (02-28-2012)
Old 02-28-2012, 06:28 PM   #15
Old School
Willie T's Avatar
Not sure, but I think "jointery" has something to do with smoking weed.
Willie T
Painting walls two colors as split by a chair rail Magraloo Painting 13 01-28-2015 06:23 PM
Installing chair rail over uneven sheetrock krazykarr Drywall & Plaster 10 12-20-2011 12:51 AM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
Painting/staining crown moulding and chair rail Gypsy601 Interior Decorating 8 07-05-2011 04:51 PM
Unique Chair Rail Obstacle mormegil Interior Decorating 4 06-03-2011 07:56 PM
