Chain Drive On Garage Door Squeaks - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 07:38 AM   #1
m1951mm's Avatar
Chain Drive on Garage door squeaks
I have a very noisy garage door opener. I have narrowed down where the noise is coming from. It is the pin with teeth that drives the chain located on the top of the motor. I have used the spray silicone lub made for garage doors on the chain but that did not stop the squeaks. A lite tap with a hammer on that pin stopped the noise but it started up again intermittenly. The noise is not there everytime the garage door is opened or closed.
Any Help?????? Thanks
m1951mm is offline   Reply With Quote
Old 07-01-2011, 09:56 AM   #2
AGWhitehouse's Avatar
You may be missing a bushing. There is sometimes a plastic (or other material) piece that sits between the moving and stationary parts. You may try some grease, not the spary kind, the thick goo kind. It may only be a temporary fix though, if you are indeed missing a bushing. You may have to take the sprocket off to get the grease in there good.
AGWhitehouse is offline   Reply With Quote
Old 07-01-2011, 10:14 AM   #3
m1951mm's Avatar
I would not know where to start to remove the sprocket. Since the chain goes on it with some tension, I am a bit afraid that I could make matters worse, like a door that does not work at all!!!!
Old 07-01-2011, 10:42 AM   #4
The chain has a tensioner located where the garage door attaches. If you loosen that the chain loosens and you can take it off. To put it back, you replace the chain on the sprocket and then tighten the tensioner. If this sounds too daring then you might want to call your favorite "handy man" and ask them to take a look.
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 05:34 PM
Garage Door Openers: Belt or Chain JPM General DIY Discussions 16 12-09-2010 02:58 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
